Has anyone actually installed a ram air setup on their tpi equipped cars?
Old May 23, 2001 | 04:45 AM
89IROCZZ4's Avatar
I am very interested in the "cheap to free" mods, and remember reading articles such as the ram air mod we can do on our cars. How diffacult is this to do? Has anyone done it themselves? Anything else needed to be done along with it to work? How much gain did you notice, if any? Any help on this is greatly appreciated!
Old May 23, 2001 | 05:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check the tech articles here, there are plans for it. I did this on my car and I gained 1.5 MPH in the 1/4.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 23, 2001 | 07:23 PM
IROC KID's Avatar
You can go to www.iroc-z.com and look in the tech articles and it shows a detailed how to on making a ram air set up,it will cost about $40 at home depot for the materials,i hear its good for about 20hp when incorporated with an airfoil and k&ns, perhaps even more,if you cant find the article then let me know and i will have my friend Sandy Mandel send you the info,he built the one on iroc-z.com,its a good set up and allows you to keep the fog lights too if you have an iroc.
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
[This message has been edited by IROC KID (edited May 23, 2001).]
Old May 24, 2001 | 01:25 AM
Kevin91Z's Avatar
I removed my foglites and gained 4 tenths, but it was two different tracks and weeks apart, so not much of a comparison. But I've since left the foglites off.
I'd like to see someone with a ram-air setup like this make a couple runs with the foglites in, and then remove them to see. They're held in by two bolts each, really easy to get to.
Old May 24, 2001 | 07:46 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Just my .02, I feel cold air inductions is better than RAM air. Cold air benefits the car all the time while Ram air only comes into play above a certain speed and only if the hood scoop is in the air stream.
I had a cold air intake I built that went were the charcoal canister is on a camaro. I drilled a hole thru that pan (firebird battery pan) and mounted my K&N cone filter under the car. When I would go drag racing, I took the filter off (I know, not good for the car but neither is drag racing )and ran some dryer duct hose to the front end spoiler. Instant ram air at the track.
I know that brandtmann@aol.com is setting his 91 RS up with TPI and the SS style hood. He has stuff for sale on the board under Jon Brandt.
I currently have the dual SLP cold air and love it. Moving the battery was a pain but not only does the cold air improve performance, it looks pretty impressive under the hood.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 24, 2001 | 08:37 AM
91RedBigFinZ's Avatar
Why is there a difference between 'cold' air - going through where the battery used to be, or what we are refering to as 'ram' air, where it gets the air from the fog light tubes? I would tend to think that they would be the same up until the point where the 'ram' air came into effect (at high speeds), in which case the 'ram' air would have a small advantage over the 'cold' air. Maybe Im confused, but that seems to be the case. Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
Old May 24, 2001 | 11:48 AM
camaro6spd's Avatar
you are right about that one RAMAIR would be the same a cold air and would be better the faster the car goes. Cold just pulls air from were ever but RamAir pulls cold air fromthe front and then gets it shoved into the engine when the car starts to move.
Old May 24, 2001 | 08:51 PM
Rob P's Avatar
Engine: ZZ4TPI
I just think of Hood scoops that take air and Ram it into the engine as RAMAIR, like the 4th gen Ramair Birds and 4th gen SS Camaros. Now old Camaro's and Chevelles had Cowl Induction that took high pressure air from the windshield base and funneled it into the air cleaner. Cold air takes air from an area that is not heated by the radiator or engine compartment.
Is a car cover a modification if it's on someone elses car?
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old May 24, 2001 | 09:38 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
yea...
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
Moderator: PROM board at thirdgen.org
Old May 26, 2001 | 01:10 AM
90 Z28SS's Avatar
Here's a pic of my 6" diameter rubber tubes ( yes it was a ***** to get them in there ) With no fogs I got a repeatable 2 tenths and 2 mph . The tubes cost me like $12 , thats all I got in my set up
Old May 26, 2001 | 03:32 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
What about the ram air setup where u do the same thing, but put the ducts in front of the air dam and not through the driving lights area?? I've seen this, is it better than the other way??
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 26, 2001 | 07:36 AM
I would think that the in front of the air dam way would have less of an effect since the air has a further distance to travel. Doug
Old May 26, 2001 | 09:33 PM
Chaotic Firehawk's Avatar
You also don't loose ground clearence with the fog-light ram air.
1992rs/ss
Jan 31, 2025 05:10 PM
1nastygta
Oct 28, 2015 08:51 PM
jharrison5
Aug 19, 2015 05:53 PM
bryan623
Aug 10, 2015 11:33 AM
drathaar907
Aug 10, 2015 07:44 AM
