oil pressure sending unit
would someone please tell me where the oil pressure sending unit for the guage is located on the engine????????
92 z28 170,000 miles 14.20 on goodyear eagles only mods k&n and muffler fell off!
87 trans am 12.20 on motor too many mods to list
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
its at the back of the engine between the intake and the distrubitor.
at least on my 87 305 it is i would think it would be in the same place on yours
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
from the front of the car driver's side rear next to disributor tapped into the intake
its not on top of the block like most. i believe its down by the oil filter but it has like 2 or 3 wires coming off of it. can anybody tell me this is true?
If you have a guage, the connector is a single prong, and the pressure unit is two inches round by 3 inches long; if you have an idiot light the connector is a three-prong, and the pressure unit is one inch by two inches. Either way, it mounts parallel to the ground, with the threads facing the distributor, underneath it.
Hope this helps
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
New toy: '85 305TPI/700R4 Black T-Top T/A (saved from the crusher)
Hope this helps
'88 Formula 350
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The one that has been discribed previously, is the one on earlier models. Yours is incorporated in with the fuel pump pressure switch located just above the oil filter, it is a three wire plug (oil guage wire is the tan one).
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
