A new cam.
Old May 25, 2001 | 12:39 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
A new cam.
I was interested in getting a new cam for my 86 IROC with a 305 TPI, cause it has the peanut cam in it and from what I hear that is a really crappy cam. So who is good to get a new cam from? I hear Comp Cams or Crane cams are good? If I get a new cam, what exactly do I need to look for? Is there anything I have to add if I get a new cam? If there is a site that explains this, could I get an address? Or maybe a book? Thanks.
86' IROC-Z
5.0L TPI
Spohn panhard bar and LCA's
Old May 25, 2001 | 02:41 PM
maksik7's Avatar
Enter "penut cam" or "cam swap" into the search and you'll find a the exact some topic I posted a week or 2 ago.
-Max
Old May 27, 2001 | 08:54 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
I have a cam that would be perfect for your car.I HAVE A NEW NEVER USED 57-87 CAMARO OR FIREBIRD CRANE TPI HYDROLIC ROLLER CAM. THIS CAM IS PERFECT FOR GOING INTO YOUR OLDER SBC. IT IS MADE TO WORK WITH AN IRON GEAR ON YOUR DISTRIBUTOR SO,YOU DON'T HAVE TO CHANGE TO A BRONZE GEAR. IT IS BIG ENOUGH TO WERE YOU CAN FEEL THE EXTRA HP BUT SMALL ENOUGH WERE YOU DON'T HAVE TO CHANGE THE COMPUTOR OR LOSE DRIVEABILTY. I paid $300.00 for it from summit but,I will take $200.00. PART# IS 119811.if you want a pic of the cam card E-Mail me and I will send it to you.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old May 27, 2001 | 11:45 PM
R.O.B.'s Avatar
Carefull, 86 had hydrolic flat tappets, not roller. 87 started rollers.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old May 28, 2001 | 01:11 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Well, I'm not really ready for a cam just yet. I mainly want to learn about them before I get one. Thanks anyway though.
grngryoutmyway
Oct 18, 2016 05:48 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
tommy z-28
Oct 6, 2015 10:58 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Strick1
Sep 4, 2015 07:11 AM
