swap 305 block to 350
Old May 21, 2001 | 01:44 PM
AFRO IROC Z's Avatar
I have an 87 305 tpi and i want to get a 350 short block. I want to know where I can get a good short block for no more than $1800 dollars. Also, I would like to know if there are any differences, anything that needs to be changed. I was going to use all the old stuff from the 305 block until i get the money for some better parts. Finally are the stock 305 heads going to be any good on the 350 block, i know they won't flow as well, but compression will be up a little and the valves won't be as shrouded, can these heads be decent with some pocket and bowl porting and polishing and a three angle valve job. Thanks in advance for any help you can give
Old May 21, 2001 | 02:47 PM
Desert86Roc's Avatar
Go get your self a GM Goodwrench 350.....And just bolt on your accessories and intake. Then you would have a new motor with a warranty too.
oops...you will have to modify your intake bolt holes. I think that the Goodwrench motor uses older heads..but they might have a newer 87 & up roller version. That way you would not even have to mess with heads until you can afford some good aftermarket ones.
[This message has been edited by Desert86Roc (edited May 21, 2001).]
Old May 21, 2001 | 02:52 PM
camarocowboy's Avatar
I just completed the same conversion,if you have 1800 to spend,I got my premium long block 350 for 1236.00.You can put those 305 heads on and have a nice hole shot but I don't know about the top end power. As far as what you need to change,(Flywheel).If you keep the 305 injectors I suggest an adjustable fuel pressure regulator to raise the pressure,(350 performance chip),(harmonic balancer).Good luck
Old May 22, 2001 | 07:08 PM
Hey cowboy could you tell me where you got your block from. I also need to know what type of flywheel to get, and would i need a new starter. hate to beat a dead horse but i want to have everything i need before embarking on my little adventure.
Old May 22, 2001 | 08:25 PM
Lov2xlr8's Avatar
Go to www.engineconnection.com
Old May 23, 2001 | 01:41 PM
Lov,I tried to go to the engine connection site you told me to check out, but it just comes up blank. I still need someone to answer my question about what type of flywheel and whether i need a new starter and what kind. I have borg warner t-5 tranny.
Old May 24, 2001 | 11:52 AM
camaro6spd's Avatar
some should create a small tech artical on this, I would but have not done the swap yet. It will be done this summer and if no know has it up by then i guess I will have to do it...that is if i don't go all the way and install a RamJet and Vortec heads.
and for 1800 you can get a junkyard 350 and rebuild it or get it rebuilt and still have money to do the swap right and get the knock sensor, a 350 ECM, 350 injectors (get them cleaned) and then make the engine pretty and still have money left ova...
[This message has been edited by camaro6spd (edited May 24, 2001).]
Old May 28, 2001 | 07:11 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
afro if you are close to jersey i got one for you cheap it is taking up space i got everything you need three intakes 2 sets of runners 2 plenums 2 ecms new 64 cc iron heads came off of the 300 horsepower crate motor from gm plus the engine minus timing cover and oil pan.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
st.evel07
Aug 13, 2015 06:15 PM
