Vette Injectors.
Old May 30, 2001 | 07:21 AM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
Vette Injectors.
Were '88 TPI injectors 22# and will they work with my 87 GTA BL2. Also,Did '91 SD TPI set-ups use 19# injectors or 22# injectors?
Old May 30, 2001 | 08:31 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
For all the TPI engines, 305 cid got 19# injectors. 350 cid engines got the 22# injectors. This applies to all..the vette, f-body, MAF or SD. Your GTA is a 350 so you will need 22# injectors
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old May 30, 2001 | 08:44 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
not all GTA's were 350's!if he has a 5-speed it's a 305
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old May 30, 2001 | 09:23 AM
Fastcamaro87's Avatar
he said it has a B2L so theres ur answer right there, he needs 19 pounders....
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old May 30, 2001 | 04:15 PM
87POSGTA's Avatar
Car: 1989 Firebird
lol, well technically i dont have the 350 in yet. I got a 305 with a thrown bearing. And its an Automatic :-)
Old May 30, 2001 | 09:00 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
b2l is the rpo code for the 350 which came with 22 lb./hr injectors the lb9 came with 19lb/hr and you can use the 19 lb injectors up to 300 horse get a special chip or an afpr(to make up for the loss in pulse width) and you will have no problems with it
FormulasOnly
Jul 23, 2018 08:47 AM
92-Formula
Dec 12, 2015 10:34 PM
BDR
Nov 7, 2015 03:05 PM
dusterbd
Sep 29, 2015 08:40 AM
webeeZ28
Sep 14, 2015 12:00 PM
