L98 Vette heads questions...
Old May 31, 2001 | 01:40 AM
Roshambo's Avatar
Ok, you can see in my sig most of my mods. I do have new exhaust. I was able to score these rebuilt, and complete for very cheap. They are the 113 castings also. My questions are as follows:
1.What modifications if any are needed to get these on?
2.What thickness should I get for the gaskets if I dont want toooo much of an increase in compression?
3.Im going to port my plenum and everything while Ive got them off. How much of an increase should I see when all is said and done?
I think thats about it.
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, Hi Flo Cat, Edelbrock 3 point Strut Tower Brace, more mods to come...
Old May 31, 2001 | 08:51 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You will also either have to change your EGR system to a vette version, or disable it in your computer. Other than that, someone else should chime in.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old May 31, 2001 | 09:55 AM
Guest
Guest
Posts: n/a
The heads will bolt up fine, but you will probably have 2 problems:
One of the bolt holes for the accessory brackets is probably missing. No biggie, carefully drill+tap.
The center 4 bolts in the heads are at the old angle, so your intake base will need to be modified to work. Its another minor change, you have to elongate the holes a little... and machining a flat area would be a nice touch.
Misread the engine size... refer to post below about compression.
[This message has been edited by madmax (edited May 31, 2001).]
Old May 31, 2001 | 11:25 AM
Todds1987iroc's Avatar
I just put these heads on about three months ago and this is what I did. The corvette heads have the same size combustion chamber as your 305 heads (58 CC) so you will not increase your compression. The head gasket I used had a compressed thickness of .028" and it's GM # 10105117. This gasket should keep your compression close to stock. GM used a steel shim gasket stock on our engines. As for the EGR I just left is hooked up like the passages were still there so the ECM thinks it still works. I have not thrown a code yet. As for porting I cleaned up the bowl area and gasket matched the heads to the intake. When I put my heads on I also put on headers. If you do not have headers yet, I would make that your next mod after putting the heads on because with the heads and porting you should have no problem getting air into the engine just getting it out will become your restriction.
1987 Camaro IROC-Z w/ 305 tpi/5-speed/9 bolt 3.45 gear/L98 Corvette heads/ T.E.S. headers/ LT4 production cam/ 1.6 rockers/ Flowmaster exhaust/ K&N filters/ MSD coil/ & other free mods.
1969 Camaro with '96 350 vortec truck engine with many mods.
2000 Chevy Silverado 4X4
Dale Earnhardt... NASCAR's greatest Champion
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
86White_T/A305
Aug 17, 2015 12:16 AM
