which emissions stuff to take off
Old May 29, 2001 | 07:51 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have a 91z28 that will be seeing some meduim modifications to it. I have a pair of SLP 1 3/4 headers and dual 3" random cats. My question is which emissions stuff can I rip off without making the computer go into limp mode. I wil be keeping dual cats on the car to pass emissions but the smog pump has to go in the trash. if i toss the smog pump and all the hoses then do I need to keep my EGR vakve. What gains are made by blocking off the EGR valve? My headers have no AIR tubes either.
Old May 29, 2001 | 09:57 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I removed my smog pump on my 89 IROC and got the correct belt and had no problems. as far as the egr i think you will have to reprogramm your chip to eliminate egr.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
Old May 30, 2001 | 11:13 AM
Steve89GTA's Avatar
My car is running very well with the EGR vac line to the solenoid disconnected. It needs less gas for passing/accelerating and doen't hesitate or bog anymore....but it's illegal.
Old May 30, 2001 | 05:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
So I can just block off the egr hole on the intake. I have to get a custom chip bunrt for my car anyway after I get my engine all put together so I will just let the company know. I just hate all that emissions and usless **** under the hood. I trashed my fuel canister on my last 91z28 and just left the line from the tank open. is this bad or harning anything
Old May 31, 2001 | 02:46 PM
Lotsokids's Avatar
Does North Carolina have vehicle inspections or emission testing? I used to live in Charleston, SC (no inspections or testing) and had an '84 Trans Am. I installed a "plain-jane" Chevy 350 with an Edelbrock carb and pulled out about 2 miles of wires, removed all sensors and then pulled the computer out and threw it into my shed (literally). Then if that wasn't enough, I cut off the muffler, took out the catalytic converter, and clamped a "glass-pack" muffler in its place. All you need is 12 volts, gas, and air. That was one of the best vehicles I ever owned (and the most politically incorrect). The check engine light was on, but could have removed the bulb if my arm was 2 inches in diameter.
Old May 31, 2001 | 03:01 PM
Lotsokids's Avatar
OOPS- I see you DO have an emissions test... nevermind all of my rambling. good entertainment, though.
Move to South Carolina.
[This message has been edited by Lotsokids (edited May 31, 2001).]
Old May 31, 2001 | 06:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
I now live in mass and they are real strick on emissions.
Old Jun 1, 2001 | 01:54 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by BOTTLEDZr28:
So I can just block off the egr hole on the intake. I have to get a custom chip bunrt for my car anyway after I get my engine all put together so I will just let the company know. I just hate all that emissions and usless **** under the hood. I trashed my fuel canister on my last 91z28 and just left the line from the tank open. is this bad or harning anything</font>
No. That vent line can be open to the atmosphere with no problems at all - as long as you put a hose on it and route it someplace where water cannot find it. Wouldn't want water finding its way into the tank .
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jun 1, 2001 | 02:02 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I would experiment with the EGR to see if ya get any gains. Seeing what EGR stands for, I would think that it would increase your mpg slightly and make the air we breath just a bit better .... every little bit counts.
The EGR recirrculated gasses might raise the temp of the intake air, thus making small performance gains. Just unhook it at the track.
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, 1000-CFM Demon Carb, Phase VI Chevy Bowtie Heads 2.05/1.60, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto Daily Driver: minor motor mods, more suspension stuff. MODS
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
