1987 gta new engine
Old Dec 15, 2007 | 06:44 PM
wes's 87 gta's Avatar
Car: 1987 gta
Transmission: 5 speed
Axle/Gears: 9 bolt 3:45
1987 gta new engine
l have put a new engine in my car, and will only run on the right side? l have pulse to the injectors, spark to the spark plugs. However it won't run on all eight cyls. l have put injectors out off a 96 z 28 26 lbs injectors! Please help it is driving me crazy!!!!!!!!!!!!!!!!!!!!!!!!!!! my car was a 305 tpi 5 speed car' now 355 tpi 5 speed!
Old Dec 19, 2007 | 09:08 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
Re: 1987 gta new engine
Just checking, has the computer been programmed for the modifications?
Old Dec 19, 2007 | 11:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
How do you know the injectors are pulsing? Do they have +12 and the ground is switching? The right and left are on separate circuits.
Old Dec 20, 2007 | 10:12 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
check your fuses,i think theres actually two different fuses 1 for each side ,later jimmy
Infested
May 22, 2018 11:56 PM
gta90
Sep 15, 2015 04:00 PM
TA8487
Aug 16, 2015 12:21 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
