HEY I JUST BOUGHT A 89' FIREBIRD...CAN YOU GIVE SOME ME SOME INFO ABOUT ABOUT IT.
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
I just got back from buying an 89' Firebird formula. The body has 156xxx miles on it and the motor and tranny where both swaped with ones that only has 75xxx miles on them. The tranny is good the clutch is good it runs good but will need a tune up. Can you guys tell me what octane gas you run thrugh yout 305 tpis..Yes it is the 305 T.P.I Also what kind of air filter oil filter Ect Ect..im in colorado..(In case climate will affect anything.)
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: HEY I JUST BOUGHT A 89' FIREBIRD...CAN YOU GIVE SOME ME SOME INFO ABOUT ABOUT IT.
Go to autozone.com, choose your car & motor, then under "Routine Maintenance" you will see the proper oil filter, air filter, etc.
Hope this helps!
Hope this helps!
Transmission: M5
Axle/Gears: 372's
Cool thanks. Also None of my interior lights work..i checked all the fuses and all of them are good and all the bulbs are good.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
