Have a question.
Old Jun 1, 2001 | 10:06 PM
tach'n_8000's Avatar
Have a question.
What are all the power diiferences of all the engines in 88-92 thirdgen v8s and engine names like L98.I would greatly apperciate it if it had HP and torque. Thanx.
Old Jun 1, 2001 | 11:53 PM
IrocNround's Avatar
Here is the specs I have for an 88 L98 TPI
- 350
- 5.7
- 230hp@4000rpm
- 300ft.lbs. of trq@3200rpm
Old Jun 4, 2001 | 09:24 PM
89ROC's Avatar
L98 (350tpi) was 230hp/330tq
I believe the 1LE care were 245/345
The LB9 (305tpi) was 190hp/285 tq
This is all strictly off the top of my head....somebody correct me if I'm wrong.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
Old Jun 4, 2001 | 09:52 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Look at the Technical Data section at this site (thirdgen.org). It has almost all the data you seek.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jun 5, 2001 | 03:44 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
top of the line i believe was the 90-92 cars 245hp and 345 tourqe
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
