85 to 89 TPI harness questions
Old May 31, 2001 | 11:32 PM
MeanTA's Avatar
Ok I swapped the harness in but there are plugs left over on the inside of the car by the ecm. The new ecm plugged in fine but what do these two other plugs do my new harness doesn't have the jacks to into these. Any ideas would be great thanks
Old Jun 2, 2001 | 01:02 PM
irocrob's Avatar
Car: 1985 Chevrolet Camaro IROC
I have an 85 IROC. I have about 2-3 extra plugs (whitish, clearish in color) in addition to the ECM. I currently do not know what they are for, but they are sure utilized in my car. Get in contact with me, I live about a half hour from you in Newton, you can take a look at what I have.
irocrob@webtv.net
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
Old Jun 2, 2001 | 03:47 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
most likely they are for a buffer of some sort its aa little yellow box 3x3 and about 1/2 in thick
Old Jun 3, 2001 | 01:42 AM
trickfbody's Avatar
Sounds like the MAF burnoff relay to me.
You didnt give enough info........like does it run? Any sos codes?
Old Jun 3, 2001 | 07:14 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
How about the cannister purge, the air diverter, and the other plug for the air pump solnoids.
Old Jun 3, 2001 | 08:41 PM
Steve87Pont's Avatar
If your speedo is cable driven (I believe it is for '85) Pete is right. Those would be for the speedometer buffer as described.
Old Jun 4, 2001 | 09:47 AM
MeanTA's Avatar
Ok guys I tore the 85 harness down and tracked the wires one plug is for the injectors and the other is for the MAF burnoff relay the 89 harness eliminates all of that so basically they will serve no purpose. Thanks for the all the info guys. IROCROB thanks for that offer that was really
cool man hey by chance what year is your car
and are you in need of parts for it such as hood driver fender and tons of other IROC stuff let me know. meanta2001@yahoo.com
Thanks guys
Old Jun 5, 2001 | 04:09 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
Guys I did this swap and you can't use the same wiring harness or Mass air sensor, you can use the harness but it will have to be modified check out www.speedscenewiring.com there are the guys that did mine. The 85 computer has a mass air burnoff relay that piggy backs the computer. The 89 computer has a VATS device (vehicle anti theft system) and your car will not run unless this is overridden. I hope this helps.
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
