TPI Question( Help ASAP!)
Old Jun 6, 2001 | 10:10 AM
David Culpepper's Avatar
Ok I am in the middle of putting aftermarket valve covers on my '91 Z w/ a 350 TPI engine.
I need to know what the H-E-Double hockeysticks is the hose that runs from the top left throttle body to the the valve cover? Can this be discarded and blocked off? Any help would be much appreciated.
Old Jun 6, 2001 | 10:34 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its the breather for the valve cover. You can block the hole on the TB and put in an aftermarket breather, but I would stick with the hose from the cover to the TB. Its to let pressure out of the engine I beleive.
Old Jun 6, 2001 | 10:54 AM
Scubaguy's Avatar
That is part of your PCV system with out it your PCV will not function properly and you may have some odd things happening with your engines running condition.
Just check the Haynes manual for a complete list of symptoms from a non-working PCV.
Mark
1988 Trans-am GTA, 5.0l, TPI, T-tops, Mac STB, Mac SFC's,
K&N Filtercharger, Vortex Cat Back
Best e.t. 15.48 @ 88.26 MPH
Member of Toronto F-Body Motorsports http://www.tfbm.org
my car page http://www.fortunecity.com/silversto...5/carspage.htm
Old Jun 6, 2001 | 12:54 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
<font face="Verdana, Arial" size="2">Originally posted by Scubaguy:
</font>
The PCV is in the drivers side cover and goes into a port between the runners into the manifold not the TB
Old Jun 6, 2001 | 03:53 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
<font face="Verdana, Arial" size="2">Originally posted by Mkos1980:
The PCV is in the drivers side cover and goes into a port between the runners into the manifold not the TB</font>
The PCV valve is on the driver's side, you are correct. But the breather is part of the PCV system, so so was he.
...ed
Old Jun 6, 2001 | 08:30 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
David:
You wouldn't happen to have any relatives that run over at EAMS would you? Seems like I remember a Jeff Culpepper or something.
Old Jun 6, 2001 | 09:36 PM
I am not related to Jeff Culpepper, but I know who you are talking about. Know several of the guys that race over there. I go over to the Phenix City Drag Strip pretty often also. You might see me over there or at EAMS.
Old Jun 6, 2001 | 09:42 PM
And thans for the help. I figured that it had something to do with the circulation of the PCV system.
Old Jun 6, 2001 | 10:14 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I am here to tell all of you that running an open element breather on the passenger side rocker cover and blocking off the port on the TB, works just fine and:
a) does not mess with the PCV system
b) does not affect the idle and
c) does not affect any of the computers inputs from the engine - even if it is a MAF system.
As long as the port is blocked off on the TB, it will not trigger ANY DTC's (if the car has a MAF system and if the port on the TB is open the engine will get some air 'leaking' into the intake stream behind the MAF that will not be properly metered by the MAF sensor which is a no-no). The PCV valve and hose on the driver side, is ported to the intake BEHIND the throttle plates and therefore is not affected by any change in the breather system that is BEFORE the throttle plates. The PCV valve on the driver side rocker cover IS supplied with vacuum and therefore IS factored into the idle tables in the EPROM. If it is replaced with a breather or plug and the port on the intake blocked off, a DTC will likely be set and it will idle erratically at the very least. I have never attempted to do this since I know that the engine does in fact need this particular component (in stock trim). The engine does not, however, NEED the breather system on the passenger rocker cover. The breather system on the passenger side rocker cover is ported through the TB, in front of the throttle plates (ie. no vacuum is supplied to it) and therefore will not affect the engine negatively if it is unused. I know this all to be true because I have done this with both of the TPI cars I have owned (both MAF) and on other cars that my friends' have owned and never had a DTC or any other problem with the engine.
However, if your engine has a lot of miles on it, it may have excessive blow-by and expell so much oil out of the open element breather that it gets on your rocker cover and other componants near by. If that is the case I would keep the breather hooked up to the TB as it keeps the engine bay cleaner.
Now that that is cleared up...... lol....
Laterzzzzzzzzzzzzzzzzzzzzzzzzz
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
BlueIroc-Z
Jun 9, 2019 03:22 AM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
