Cam, Intake, Rocker arm combo?
Old Jun 4, 2001 | 08:59 PM
91RedBigFinZ's Avatar
Ok. Ive decided to get a cam. My current mods are in the sig. I have gathered that I need a cam with about 112 degrees of lobe seperation, but am a little confused about the amount of lift I will need. The TPIS ZZ9 seems a good choice, but is expensive. What is a good alternative to this cam, or is there a better option?
With that decided, Should I go ahead and get 1.6:1 roller rocker arms on intake and exhaust or keep the intake 1.5:1 or neither? New springs? Will these fit under the stock valve covers?
Should I go ahead with an edelbrock or accel intake while I am at it (with my SLP runners)?
Will my 'off the shelf' Fastchip be lacking when I do all of this?
Is there anything else that I have forgotten, or that you guys would suggest? Should i wait for new heads? And the million dollar question.. what will the Horsepower gain be?
Thanks, Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
Old Jun 7, 2001 | 11:59 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I would wait on the heads. The bigger cam will be limited by what the heads will flow. Go w/ the edelbrock base and port match it to your plenum and your plenum to your runners and tb. Since you're buying a cam I'd go w/ the 1.5 rockers for less valvetrain wear.
There's ALWAYS an alternative to the overpriced TPIS parts. What cam you get depends on what heads you're going to be buying. Save up and do it all at once. If you have a fastchip from ed wright he will need to reprogram it for you (should be free) after the mods.
oh yeah, don't get crazy on the lift w/ the stock bottom end, I found that out the hard way.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
