Differences in TPI plenums?
Old Jun 5, 2001 | 02:08 PM
AlexJH's Avatar
Engine: 5.7L V8
I'm wanting to port and polish the plenum on my 89 Formula 350, but I'm going to try and find one in a junkyard or on Ebay that I can work on, since this car is a daily driver.
My question is what years of F-bods and Corvettes are the same? From what I've read, I want to find 89 or up because the earlier years had the cold start injector.
There is a big Corvette shop in town, I'm sure they will have one that I need, I just need to know the year. Any 'Vette specialists here?
Thanks,
Alex
Old Jun 5, 2001 | 03:39 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the cold startt has nothing to do with the plenum. anything from 85 to 89 will work the 9th injector sits in the driver's side runner bolted to the intake so any maf plenum will work possibly sd also but not sure
Old Jun 5, 2001 | 08:34 PM
WHITE87GTA's Avatar
i just did my plenhiem recently and it took about 8 hours in total to remove,port, re-assemble and reset IAC/TPS....i also installed a AFPR at that time..it is a good time to do the AFPR if you have one as you already have the plenhiem off. so if you have a day off it can be done in one day.
Old Jun 5, 2001 | 08:42 PM
NavyVette's Avatar
The only differences between the maf plenums and the map plenums I believe is the place where the map sensor mounts on the passenger side.
Jeff
Old Jun 5, 2001 | 09:47 PM
mjdoyle's Avatar
any recommendations on an AFPR?
What type should i buy and at what pressure should i run it???
What are the costs as well
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Old Jun 5, 2001 | 09:54 PM
WHITE87GTA's Avatar
in regaurds to AFPR settings i can only speek from my expierence....i am using the holly afpr..it cost $180 CANADIAN. i picked it because it was adjustable by a dial instead of using a allen wrench but i had to grind down the head of dial....it was interfering with the plenhum. i found the best pressure for my set up was 51 lbs. i started at 46 and worked my way up to 54 and best et was attained at 51 lbs.
Old Jun 6, 2001 | 06:06 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
All plenums are the same except as mentioned the provision for the MAP sensor.
Don't get the Accel AFPR. When the guts wear out you have to buy a whole new unit. You cannot replace it with stock FPR guts and Accel does not just sell the inner part. My JET I had to find a new set bolt at the hardware store. It came with some ridicuously small bolt head that was too long and bumped into the plenum. Plus the cost was like $65 for just the shell! I had to buy a stock FPR from NAPA to fill my $65 shell. You may want to check out the tech articles on making you're own. Seeing how my JET works I don't see any safety issues at all.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jun 8, 2001 | 08:41 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Maybe you might like the ported, powdercoated, and laser etched plenum I have sitting here next my computer. It came off a 1989 Camaro Z28 and is ready to go.
Aw Nuts! I forgot! You have a formula, not a Trans Am. I *knew* I should have etched "PONTIAC" in there instead of "TRANS AM"!
Just a thought.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
[This message has been edited by ws6transam (edited June 08, 2001).]
MantyZ28
16
Dec 21, 2015 11:02 AM
masonta
Aug 31, 2015 10:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
