Working EGR with ZZ4 heads
Old Jun 6, 2001 | 03:22 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
For the sake of increasing gas mileage and ease of chip tuning, I want to get my EGR system working on my current setup (see mods below). I have to tap into the number #8 header tube to make this work, and I am looking for a premade tube that I can either have a bung welded onto the header, or just use a compression connection to attach it. I found this at the impala club web site, but I don't think it's quite what I am looking for:
Anyone have a part # (like from the 89 vette) for a tube that I can use? Also, what did you use for the header bung?
Thanks,
http://www.havemann.com/lee/firebird.html
1989 Firebird Formula, WS6 Package
ZZ4 Crate engine, Accel 24 pound injectors, Accel Superram intake, Accel Large tube runners
SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust, Random Tech 3" hi flow cat
700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band, 2200 rpm stall converter
Borg Warner 9 bolt rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's, Spohn subframe connectors, custom chip.
[This message has been edited by LeeH (edited June 06, 2001).]
Old Jun 7, 2001 | 01:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Here's the pics of what I did:
http://24.1.139.249/images/021701/
Basically I just used some junkyard parts and welded that bung to my SLP 1 3/4" headers, and connected it to my TPIS big mouth intake manifold.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 7, 2001 | 08:02 AM
LeeH's Avatar
Engine: 389
Kevin,
What year/make/model of car did you get the
tube and bung from? They are exactly what I need!
I can't tell from the pics - is the flanged opening on the manifold identical to the one on the header?
The local boneyards around here are pretty lousy, so I may try to order the tube direct from GM. Dunno about the bung, but I can probably scavenge one from somewhere...
Thanks.
Old Jun 9, 2001 | 01:53 AM
Kevin91Z's Avatar
You can get one from a L98 Corvette, and then modify your header to fit it. I dont remember what car exactly it came from, I do remember it was a V6. They have those EGR tubes going to the throttle body. I got two and put them together.
Old Jun 9, 2001 | 11:38 PM
need4speed's Avatar
It looks exactly like my lt1 tube.
They were also on the lt1 cop cars.
1992rs/ss
Jan 31, 2025 05:10 PM
italiano67
Dec 11, 2016 09:21 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
drathaar907
Aug 6, 2015 04:20 PM
