lt1 clone intake
Old May 26, 2001 | 09:21 PM
mirage2991's Avatar
lt1 clone intake
ok I'm looking at geting this intake off E-bay, it's for L98, looks like an Lt1, but has a dist hole out back and the guy said to me it's out of GM's r&d
Part# is IL48049
Could anyone check this # for me....have you guys ever seen that before? (go check e-bay)
IT could be a nice alternative to the Miniram, maybe not "As good" but a better alternative than ltr set up...
anyway, I think I'm gonna get it....but gimme your opinion first.
thanks guys
Old May 26, 2001 | 09:25 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
yeah i've seen these before!the LT-1 intake is one of the main reasons why an LT-1 makes more power than a L98.if you can afford it get it.i would
hey you said it was on e-bay?hhmmm???
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old May 27, 2001 | 12:55 AM
mirage2991's Avatar
yeap it is, and I want it...so go away...LOL.
That's basically why I think it'll do great on my L98....hehe
Old May 27, 2001 | 01:03 AM
NavyVette's Avatar
Could you give an auction number? Can't find it on ebay. I think it would be great if it's not bad expensive. The miniram with fuel rails costs almost a grand.
Jeff
Old May 27, 2001 | 01:31 AM
91banditt2's Avatar
Engine: 5.7 HSR
yeah that LT-1 intake would work great on a L98
Old May 27, 2001 | 09:53 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I know LT1 heads are different because of the reverse-flow cooling, but aren't the intake/head suface different too? I thought that was why you never see someone running them on a genI SBC.
I saw an auction for LT4 intakes for $200, ported and polished for alittle more $$$, FYI. I had a '96 'Vette crate motor I was going to make a 396 out of (rod knock), but sold it instead.
Old May 27, 2001 | 11:12 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
yeah could u give me the Ebay auction #? i would love to see that part just out of curiousity...or..how would i look up that part # u posted?
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old May 27, 2001 | 01:01 PM
kevinc's Avatar
Car: 1982 Z28
If it's this one:
http://cgi.ebay.com/ebaymotors/aw-cg...item=591670767
...it looks like a TPIS Mini-Ram 1. Note the lack of a throttle cable bracket mount, front coolant exit, or CTS hole. Lots of gripes about these led TPIS to re-cast and create the Mini-Ram 2.
The 1 and 2 flow the same internally and if you can work around the details above it's a great intake.
Be advised you'll need TPIS fuel rails and their modified thermostat neck to bolt it up...looking at around $300-400 above whatever you pay for the intake itself.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old May 28, 2001 | 01:29 AM
mirage2991's Avatar
and it's not an TPIS intake, it's a GM intake....
Old May 28, 2001 | 01:40 AM
Slow Iroc's Avatar
WTF, look at the bottom pic, is that an EGR port? If so, that's no MiniRam. Many things on it look...incorrect. Where is the tube for coolant flow, and if not tube how about just the port! Approach this items with caution, looks to be a little shady.
Old May 28, 2001 | 10:33 AM
GhoSSt's Avatar
Thats an early LT1 prototype intake. There is a engine & tranny at a local junkyard in Denver that has an LT1 and ZF6 6 speed transmission and it has a similar intake on it. The car was a 1990 Z28, they were using it for high altitude testing.
The whole point want merely to test the flow characteristics of the manifold, but still use a conventional distributor since the whole Optispark deal wasn't quite ready for prime time.
There are NO coolant passages in that intake, as well as the obvious lack of a thermostat housing, etc..
Old May 28, 2001 | 12:23 PM
mirage2991's Avatar
ok so is that mean that without the coolant passages, the engine is going to over-heat??
Old May 28, 2001 | 12:25 PM
Guest
Guest
Posts: n/a
It means there is no place to hook up your upper radiator hose as it sits. I guess you could say it would overheat since the cooling system would be effectively bypassed if you didnt use some other method of getting the coolant out of the heads.
Old May 28, 2001 | 12:38 PM
GhoSSt's Avatar
You could fabricate a coolant crossover tube, like the circle track guys go. But in the end, you'd have so much in fabrication, that you could have just bought a miniram allready.
Kelly 'GhoSSt' Rosato
Old May 28, 2001 | 10:04 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
GhoSSt- is that engine/trans combo still in the car???? If it was, holy crap that would have to be worth some cash.
Old May 28, 2001 | 10:42 PM
Slow Iroc's Avatar
Maybe you meant 1990 IROCZ (there were no 90 Z28's, they came back in 91.)
Old May 30, 2001 | 10:17 AM
GhoSSt's Avatar
<font face="Verdana, Arial" size="2">GhoSSt- is that engine/trans combo still in the car???? If it was, holy crap that would have to be worth some cash.</font>
No, it sitting on the shelf rotting away because the stupid junkyard owner is too dumb to decide what he wants to do with it. Oh well. The car is long gone, GM brought it in to crush, the yard did a light roof crush on it (just enough to damage the top). Then once GM left, they snatched the engine and tranny out.
<font face="Verdana, Arial" size="2">Maybe you meant 1990 IROCZ (there were no 90 Z28's, they came back in 91.)</font>
I wasn't there when the car came thru the yard, so all I can go by is what my former associate said. Perhaps the mule had some decals or something on it unusual. Dunno. Unlike many of the other prototype I've seen or seen pictures of, this on had both a optispark up front (functional) and that prototype intake as well. No injector covers, or engine dress, but it did have the Corvette magnesium valve covers.
HTH
Kelly Rosato
[This message has been edited by GhoSSt (edited May 30, 2001).]
Old Jun 13, 2001 | 12:52 AM
JERRYWHO's Avatar
GhoSSt:
Do you have the name of the yard that has the intake.
I can use one more of them.
Thanks for any info you can supply.
Jerry
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EIBACH spring kit, NITTO'S, N.O.S.
best 60ft 1.84 1/4 12.48 @ 110.81
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
