Injectors
Old Jun 3, 2001 | 12:07 AM
AFRO IROC Z's Avatar
Injectors
I want to get new injectors for my 305 tpi. But most injectors are very expensive. Accel makes fairly inexpensive injectors but they don't make the 19lb. injectors for my car. They do make 22lb. injectors for my car though. I have and afpr on my car now. I was wondering if my car would run right with these 22lb. injectors on my car. plus sooner or later i want to switch my car over to a 350, anyway. If not does anyone know where i can 19lb. injectors that good quality at a fair price.
Old Jun 3, 2001 | 02:15 AM
ScreaminDeamin85Z's Avatar
try summit racing, they have the SVo 19#'s for a great price. last time i checked they were like 195 or so.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Jun 3, 2001 | 05:36 PM
rondubbs's Avatar
try ebay,, you can get a set of 19lb real cheap.. when you get them send them out to get cleaned and tested by rich @ http://www.cruzinperformance.com/fuelinj.html
Old Jun 3, 2001 | 10:51 PM
Are the svo 19lb. injectors as good as the gm and accel 19lb. injectors(will they support 400 horse like the stock tpi injectors supposedly will.)
Old Jun 4, 2001 | 12:25 AM
leirch's Avatar
They should actually support more, svo 24's actually flow at 26lb gm specs. so i would "imagine" that the 19svo's would flow at 22 or close to it??
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 4, 2001 | 11:31 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Contact Rich at Cruzin Performance (do a search for the correct URL and/or his email addy), he carries the Accel injectors, I believe 18#er's through 30+#'ers
Old Jun 13, 2001 | 04:16 PM
LeftTurn1LE's Avatar
jegs.com has them. part# 110-150819
Old Jun 14, 2001 | 08:36 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I would just take the injectors you have and send them to rich at cruzin performance.
for about 100 bucks he will rebuild and flowmatch them, and include the cold start (if you have one) and the gasket set you need.
If you do this I would recommend getting the GM o-rings for your injectors. It will cost you an extra 20 bucks but they are big, blue, and beefy and I had better luck than the stock new o-rings that come back your rebuilds.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
