TPI Air Cleaner assembly on a camaro
Old Jun 17, 2001 | 11:03 PM
n9zda's Avatar
Does anybody here know if a TPI Air cleaner assembly with the two square filters will fit in a 1986 pontiac firebird. I know there are small differences, but for my motor swap, I hope this will work..
Old Jun 18, 2001 | 01:46 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
the core support panel there is quite different, so you'd have to modify tremendously, if the hood even allowed it to fit.
jmd
L69 / T5
Old Jun 18, 2001 | 07:49 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the firebird hood sits lower than the camaro hood does so you would have to modify the under side of the hood to make this work(that's if it would work at all).you would allso have to cut alot of metal out of the core support.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 18, 2001 | 09:18 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
NO, since the hood is less than a 1/4 of an inch from the core support on a Firebird, there is NO way, if you are going to stay with the stock hood.
87 Formula 5.1 converted to TPI Yellow/Black
SLP Dur 206/212, Lift 480/487, Cent Line 112 cam, SLP headers, SLP cat-back exhaust
Modified Stock cold air intake
Ported & polished Stock TPI intake
AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 18, 2001 | 06:10 PM
n9zda's Avatar
That is what I was thinking too. It looks like I will have to try something different with the new motor..
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
