timing/idling problem
Old Jun 19, 2001 | 12:06 PM
Ryebread1979's Avatar
My 350 TPI has a problem with idling. When its in drive, the car bounces from 750-500rpm, and seems like its going to stall out. When my friend adjusted the timing a bit on the distributor, it idled perfectly, but accelerated slower than my mom's SHADOW. When he put it back to the bad idle, it regained all its power.
Do I have a vaccuum leak? Or is there some other way to set the idle?
I'm not exactly sure of all the modifications that have been done to the engine, since its not stock. The guys at firestone weren't going to touch it until they knew what's been done to it. I could find out all the mods, but its going to take some time to track the kid down.
Any help is appreciated.
Ryan G.
Cars:
1986 Camaro IROC-Z
350TPI
1979 Camaro Sport Coupe
Unmodified 305, for sale
1993 Dodge Stealth R/T 5 speed
Complete engine rebuild
1992 Dodge Shadow Convertible
Old Jun 19, 2001 | 12:30 PM
whiterocz's Avatar
did you disconnect the EST bypass wire? its the brown wire with a black stripe running up near the firewall on the passenger side. its got a big black connector on it. you need to disconnect that wire then set the timing.
[This message has been edited by whiterocz (edited June 19, 2001).]
Old Jun 19, 2001 | 02:17 PM
Thanks for the reply.
How simple is it to set the idle? I've only done minor engine stuff (water pumps, radiators), and don't wanna mess anything up. Do I need any special tools to do it?
Sorry, I'm still kinda learning about this stuff.
Ryan G.
Cars:
1986 Camaro IROC-Z
350TPI
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
