Code 42 EST problem...again :(
Old Jun 17, 2001 | 08:43 PM
IROC5.7TPI's Avatar
I took out my ignition module and found some corrosion on the leads that go to the pickup coil and also found it to have very little dilectric grease. So I cleaned the contacts with a file and re greased the mod and put it all back together.
Now I only get code 42 when the A/C is on and blowing cold.
I got the car hot the other day (bad fan relay) and didn't have any problem with codes at all, so its not temp related.
It runs fine even when it triggers the SES light, and never stutters or anything at any time.
I am thinking the pickup in the distributor is maybe cracked???
Input appreciated.
Mike L.
"If it feels good - stay in it "
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jun 17, 2001 | 10:34 PM
whiterocz's Avatar
my brothers 88 tpi corvette is throwing a code 42 right now. we have changed the ignition module 3 times, cleaned all connections, and looked all over for a problem but we have yet to figure any thing out. his runs like chit though when the SES light is on, even dieing the first couple of times you start it. after you drive it for a while, kill it, then restart it, it runs normal with no light and without hesitating. the only other thing i can think of is the ecm, but i cant figure out why it would get better after you drove it a while if it was the ecm.
Old Jun 18, 2001 | 01:40 PM
IROC5.7TPI's Avatar
After getting some advice from friedns I have come to the conclusion that the magnetic pickup in the distributor may have a crack in it.
It figures....I guess I'll be taking the dist. out this weekend. ]
Mike L.
Old Jun 18, 2001 | 01:53 PM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by whiterocz:
my brothers 88 tpi corvette is throwing a code 42 right now. we have changed the ignition module 3 times, cleaned all connections, and looked all over for a problem but we have yet to figure any thing out. his runs like chit though when the SES light is on, even dieing the first couple of times you start it. after you drive it for a while, kill it, then restart it, it runs normal with no light and without hesitating. the only other thing i can think of is the ecm, but i cant figure out why it would get better after you drove it a while if it was the ecm.</font>
I have an electrical diagnosis manual and a service manual and a Haynes manual from my 88 Vette that I am looking to sell. I also have a K&N filter....
Let me know if he may be interested in this stuff.
Thanks.
Mike L.
Old Jun 18, 2001 | 02:14 PM
whiterocz's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROC5.7TPI:
Thanks.
</font>
thanks, but actually he already has all three! (haynes manual not wanted) let me know if you find out what the hell is causing the code 42 on your car. we are dumbfounded at his. are you talking about the pick up coil in the distrib? keep me updated.
[This message has been edited by whiterocz (edited June 18, 2001).]
Old Jun 18, 2001 | 03:28 PM
irocbsa's Avatar
This may be stupid but have you gone over all the wiring. I had this same problem and it ended up I had a bad connection at the distributor plug (white wire). Good luck.
bsa
Old Jun 19, 2001 | 02:49 PM
87iroczmd's Avatar
sounds like you have the same problem as me, get a timing light and when the ses light is on check the timing without disconnecting the est bypass, if it is at base timing with the est bypass connected then for some reason the timing is not being advanced by the computer, unfortunately i haven't found the cause
Old Jun 19, 2001 | 08:54 PM
whiterocz's Avatar
problem is solved. we took the ecm out of my tpi iroc and threw it in his tpi vette with his eeprom and it ran perfect. we took the bad ecm and put it in my car, threw the code 42 and ran like ****. im 100% sure that my car doesnt have any EST problems. the computer was the blame the whole time. it did start out as an every now and then occurance, but it got to where it would throw the code every time you started it.
Old Jun 20, 2001 | 02:22 AM
whiteroc's Avatar
Well... Whiterocz -looks like my advice about the ECM swap worked out for you somewhere at least --lol.
Old Jun 20, 2001 | 09:52 AM
IROC5.7TPI's Avatar
Thanks for the input. I am glad you got the Vette fixed!
Anyways....time to try changing out the ECM. I think my probelm started when I switched PROMs. I may have cracked the board or something.
Well....I can get a ECM for about $50 so I will try it next.
Thanks again.
Mike
Mike L.
Old Jun 20, 2001 | 09:56 AM
whiterocz's Avatar
50 bucks? where at?
Old Jun 20, 2001 | 09:59 AM
IROC5.7TPI's Avatar
50 bucks? where at?</font>
I know people high up.
Sorry, just my connection. I tried hooking people up before and it backfired, so I won't be doing that anymore. Sorry
Mike L.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
