87 Heads on a 92
Subscribe
Jun 20, 2001 | 09:22 AM
I was wondering if I could use a set of heads from an 87 IROC 350 on my 92Z 350? I am asking because a friend of mine has a set that he is not using and they have the springs that I need for the cam I am buying as well as some minor machine work.
Eric
Reply 0
Jun 20, 2001 | 05:26 PM
I think they are the same head, check the casting numbers, if they match, your good to go. 10159552 is for the part number 87 thru 91 for sure.
91 casting #-14101083 or 14096217, thats the best info I could get.
Hope it helps...
87 Formula 5.1 converted to TPI Yellow/Black
SLP Dur 206/212, Lift 480/487, Cent Line 112 cam, SLP headers, SLP cat-back exhaust
K&N Airfilter
Modified Stock cold air intake
Ported & polished Stock TPI intake
Holley Adjustable Fuel Press regulator
AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connectors
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Reply 0
Jun 21, 2001 | 07:47 AM
your good to go bro!!!
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Reply 0
Subscribe
