erratic idle when cold started.......help
Old Jun 20, 2001 | 11:52 AM
TransAm182's Avatar
when i start up my 85 TA TPI cold, the idle is all over the place... sometimes it will feel like its going to stall, but then jumps back up...i go to give it a little gas and its hesitates but after about 5 min or so it idles and runs perfect....i just replaced the fuel pump which was my major hesitation problem...im not getting any codes...i have replaced wires, plugs, cap, rotor, fuel filter and pump...now what could be wrong?? again this only happens on a cold start....
Old Jun 20, 2001 | 03:35 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
this sounds familiar...
I replaced my temp sensor in the front of my 87 Intake because it had the EXACT same problem... mine would stall though untill it began to warm up.
Question, when you first start your car does the electric fan automatically kick in, mine didn't for a while then all of a sudden when it was cold I would get a fan running when it was cold. I checked the sensor and it was ok, I changed the sensor and it cured my car. The temp sensor you might need to replace is the one with the two wire plug under your throttlebody on the intake.
The part was only 12 bucks, I had to remove the alt bracket to get to the sensor though..
John
87 Formula 5.1 converted to TPI Yellow/Black
SLP Dur 206/212, Lift 480/487, Cent Line 112 cam, SLP headers, SLP cat-back exhaust
K&N Airfilter
Modified Stock cold air intake
Ported & polished Stock TPI intake
Holley Adjustable Fuel Press regulator
AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connectors
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 21, 2001 | 11:01 AM
TransAm182's Avatar
no, my fan only comes on when it should ....
Old Jun 22, 2001 | 05:28 PM
Going Slow Sucks's Avatar
My car does this to but it only lasts for about 40sec or so. And it smells a lot like gas at first. I think it might be a leaking injector. does yours smell like gas.
Old Jun 22, 2001 | 08:00 PM
TransAm182's Avatar
acctually it does....perhaps a bad 02 sensor?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
IROCtometal
Sep 2, 2015 02:01 PM
