Did some port/paint work and Inejctor swap
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Going for a different look, with a "Low gloss black plenum, and custom painted (by me
) "Tuned Port Injection" TB plate, polished silver runners.
Reason for teardown is for an Injector issue with my Multecs. I now have LT1 injectors. I also ported the EGR walls out of the Plenum and smoothed the walls by the Intake runner outlets aswell.
The LT1 injectors are now on my rails, and everything is preped and ready for reinstallation :headbang:
Just before removing Fuel Rail :
Fuel Rail everything off, and covered for the night :
Injectors are on the rails, new orings :
Everything preped/cleaned and ready for reinstallation :
) "Tuned Port Injection" TB plate, polished silver runners.Reason for teardown is for an Injector issue with my Multecs. I now have LT1 injectors. I also ported the EGR walls out of the Plenum and smoothed the walls by the Intake runner outlets aswell.
Car: 92 trans am clone
Engine: LO3
Re: Did some port/paint work and Inejctor swap
post some final pictures of it put together on the car im curious as to how itd look.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
I think it will look pretty good
After I get it all put on my plans for spring are :
1) Run true duels back to just past transmission, go into a 2in - 1out convertor and put run it to my 3" midpipe, into the Flowmaster.
Dad has that system custoemr done, and my buddy is going to do it to mine.
2) Customer tune and burnt chip
3) Run ***** out and hope for a high 13!
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Oh my god! Got the new Injectors in, no smoke, no smell, no leaks, and NO ROUGH IDLE! 8)
Car sounds so much more healthy, and revs 10x quicker, sounds really really mean!!
Pics from today :
Did some polishing on the runners :
The put together :
All installed :
Couple of revs (the marks on the ground and wall are just water stains from over the times its been run and started in the units, there was absolutly 0 black smoke, or rich smell on part throttle, WOT or idle 8)
Click here to watch Plen-080
Click here to watch Plen-078
Click here to watch Plen-079
Pics from today :
The put together :
All installed :
Car: 1983 G20 Chevy
Transmission: 4L60
Congrats, good job there. It is amazing how far a set of 8 properly working LT1/LT4 injectors goes on these setups and how well the TPI setup responds to some porting. I cleaned up my TPI setup, especially the base and plenum, as well as used LT1 injectors @ 46 psi for my 305.
http://s243.photobucket.com/albums/f...t=100_1240.flv
http://s243.photobucket.com/albums/f...t=100_1261.flv
http://s243.photobucket.com/albums/f...t=100_1245.flv
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
How much did the LT1 injectors cost you if you don't
mind me asking? Im getting ready for new injectors
and a manifold tear down this coming week.
Are they 24lbs stock on LT1's?
I dont know who to trust for injectors, I was just going
to grab some OEM pintle-type Bosch 24 pounders.
But, if these will net me a trustworthy swap and
perform nicely then, Id like to go this route.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Got the used for $150.00, work flawlessly
93 some were #22, 94 -> all 24# if I remember correctly
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
