is there a rev limiter
Old Jan 11, 2008 | 06:50 PM
bob8703's Avatar
ok so i have a 305 TPI motor. now i asked someone on here if there was a rev limiter on the motor and he said that the limiter is set at 10000. now first off my tach doesnt even go that high. and second off when i do a burnout by powerbreaking my rpm's will get to around 6k and then drop to around 3 or 4 grand the it will go back up then back down and it repeats this till i let go off the gas and stop burning the rubber. so is this a rev limiter or is there such a major loss of power that it does that. i have read that at higher rpm's the 305 TPI starves for air. but i dont know if this is what i am experiancing or not.
Old Jan 11, 2008 | 07:21 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: is there a rev limiter
Do you have an automatic transmission?
There's no rev limiter on a TPI car from the factory.
Old Jan 11, 2008 | 07:58 PM
bob8703's Avatar
yes it is an automatic trans.
Old Jan 11, 2008 | 09:12 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
There is a rev limiter in tpi chips but its set to 10,000 rpms at the factory. Its possible that someone activated the rev limiter if you have an aftermarket chip. Check your prom chip for a silver sticker with a four letter code stamped on it by looking in one of the two holes in the blue plastic cover.. If you see a smiley face or no sticker at all its probably aftermarket.
Old Jan 11, 2008 | 09:15 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
more than likely since its an automatic transmission it is shifting gears, thats why you feel the drop. if you are daring and dont care if you motor blows up, put it in first and see what happens
Old Jan 12, 2008 | 02:52 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Even if you manually select 1st gear on the 700r4 it will still shift to seconds around 5500 RPM's. Your engine will never touch the factory rev limiter if it is set at 10K. you'll float the valves long before that.
Old Jan 12, 2008 | 06:08 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
If he does have an aftermarket chip, it takes two seconds to reprogram the rev limiter to kick in at whatever rpm you want it to, if you have the hardware to reprogram your chip that is. It shuts off the injectors at the preprogrammed rpm.
Old Jan 13, 2008 | 02:19 PM
Rduffy123's Avatar
Car: 1985 Camaro IROCZ
Engine: 305 V8 TPI
Axle/Gears: 3.42 gears
Ive brought mine into 7k territory in first and it did not shift. I had to let off the throttle because I also thought there would be a rev limiter. I guess you have to find a aftermarket rev limiter.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
