Please help me with my afpr
Car: 90 Formula
I tried to adjust my pressure today and I am having problems. I have the screw butt up against the nut down on the regulator and when I disconnect the vacuum and check the gauge and it is still at 42-43 psi. As I adjusted it it gradually went up so I guess I went in the right direction. I am pretty sure I am disconnecting the vacuum line in the right place, too. It seems to run fine except at the top of every gear at about 4500 rpms it cuts out like it is running out of something (air or fuel). Any help would be appreciated.
1990 Formula 350
*Hooker Headers
*Random Technology 3" Exhaust(no cat)
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
*Metco Lower Control Arms
w/ Lowering brackets
*F-Body Perf. Panhard Rod and Strut Tower Brace
*1999 16x8 Formula Wheels
*White Face Gauge Overlays
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Well, if you have the same problem as me, your fuel pump is junk. Mine is two years old, but I can't get any higher pressure than 44PSI. I've rebuilt the AFPR and tried plugging the return line to see if pressure would go up. My problem seems to be in the tank.
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
sounds like the fuel pump. drive the car with the guage attached so you can see it (the ones attached to a long hose are nice) and see if your pressure drops at higher rpm. it shouldn't, but if the pump or regulator are bad it will.
Car: 90 Formula
I am disconnecting it at the line that comes off of the reglator to the plenum. I got about 11 mpgs this tank. I am frustrated...
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
Ouch, thats rough.
Did you make your own FPR or buy one?
I just made mine 3 weeks ago, i didn't notice any difference no matter what PSI, but oh well, now i can burn more gas at will
1985 IROC-Z, nuff said :P
Car: 90 Formula
It is an Accel regulator. Anyone else with an idea?
If not I guess I will be going back to the stock regulator and see if my car will run any better. I guess the afpr was a waist of money.
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
Car: 90 Formula
Thanks AFRO IROC Z.
I am an idiot. I guarentee that is my problem. I must be running at 60 psi.
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
1990 Formula 350
*Hooker Headers
*Accel AFPR
*K&N
*Airfoil
*170* Thermostat
If the fuel pressure remains the same whether the vacuum line is on or off,,, then unscrew the vacuum port nipple from the regulator and make sure it is not plugged up as the Accel unit I bought was. I know at least one other person has experienced the same thing.
2012sergen11
Oct 13, 2015 07:38 PM
