gas mileage mods
gas mileage mods
I just today baught me a 88 iroc w/ 350 tpi, with gas so high i was wondering if anyone knew anything to do to make my car have a little better gas mileage along with more power. also my interior is aweful how should i replace it cheap?
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Tell us more about it. Is it completely stock, how many miles, etc.
On the easy and inexpensive side get the car tuned, new O2 sensor, plugs and of course a K&N filter or similar.
Need more, look through the archives and you will find lots of info that will help you a lot.
Good luck and welcome.
IROC 88,
Welcome aboard!
Do the basics first. Unless you have a complete repair history of the car, start performing the required routine maintenance for a car of that age and mileage.
Keep the tires inflated and the wheels aligned. That can make a big difference in fuel mileage. Keep it in tune. Replace the air filter. Change to synthetic engine oil, differential oil, and transmission oil. That alone can free up 10HP and provide the fuel savings required to maker that extra 10HP.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Welcome aboard!
Later,
Vader
headers and power pulleyes will give yo both power and better gas mileage.
and like they said a complete tune up,,, cap, rotor, plugs, wires, air filter, fuel filter, o2 sensor, injector cleaning.. etc....
Besides the good recommendations the other guys wrote, get a better ignition system -something like the MSD6A and a high output coil. The MSD coil and multispark is inexpensive and works very good for gas mileage and more power. Instead of replacing the wires with the stock types get the 8.5 - 8.8mm with as low a resistance as you can get and again the MSD is a good way to go here too. Don't forget to open up the plug gap from .035 to .050 after the ignition swap.
89 IROC-Z 5.7L
130,000 MILES
2.77 GEARS
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
Best 1/4 E.T. 14.37 @ 95 MPH
Best 1/8 E.T. 9.22 @ 76 MPH
Best 60ft. 2.07
89 IROC-Z 5.7L
130,000 MILES
2.77 GEARS
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER MUFFLER
Best 60ft. 2.07
Car: 91 Z28
Engine: 5.7
my aftermarket chip - along with my headers gave me about another 40-60 miles per tank
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
dbrochard
Oct 3, 2015 12:43 PM
TheTraut88
Sep 7, 2015 05:22 PM
