Different spin on the LT4 hot cam, come inside
ok, i have a stock LTR setup and i know that the hot cam is a bit much.
Has anyone advanced the cam while installing it to bring down more power down low where the TPI needs it?
just curious....i think that maybe i should do tests of straight up and advanced because retarding it would obviously put the powerband up too high.
any opinions?
any opinions?
Tom K. runs mid 13s with it with some World products heads, a stock looking TPI, and full exaust
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
And I run low 13's with it, faster than Tom.
I should be in the 12's...
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
I should be in the 12's...------------------
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i wish i had thetime to experiment on mine it couldn't hurt i was expecting a lot more out of mine and just don't have the timee to play anymore
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' LOOKING TO TRADE?ANYONE
I have a ported Edelbrock base (Felpro 1205 gasket)and 52mm throttle body, but the runners are stock on my car and my cam is advanced 2 degrees. I think the car feels really good, even though I am running a 2:77 rear gear right now. The car is pretty weak (seems stock) until it reaches about 2800-3000 rpm and then it starts making a ton of torque. The car feels sort of like a 2 stroke dirt bikes power band 8^) I am installing a set of 3:70 gears soon and could let you know what it does for me. I have ran it at Famoso raceway in Bakersfield California about 5 times with this motor and each time it was well over 100 degrees out. My launch sucks! The best 60' I have ever had is a 2.21, so I could do better with practice. My best time is in my signature. Hope this helps.....
1991 Camaro RS/Z28,polished TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.4 @ 104.8 with a 2:77 rear, no traction, no tuning, no practice. Car is pictured in Chevy High Performance magazine, June 2000 issue.
http://www.geocities.com/jasonsz28us/INDEX.htm
1997 GMC Yukon, 4 wheel drive, leather, loaded, Gibson exhaust, K&N intake, Boston pro series speakers..... That's it so far.
1969 Camaro,12 point cage, total project right now, I am planning an LS1 - T56 - and a Vette independent rear. Pro Touring crowd, look out! 8^)
1988iroc350tpi
Aug 14, 2015 07:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
