vacuum and cold start injector
Old Jun 23, 2001 | 09:22 PM
cobrakiller1989's Avatar
I am pretty sure that i have a pretty bad vacuum leak where my cold start injector is at. I sprayed carb cleaner on it and the car revved up. I already tried to tackle this leak once and put a new o-ring on it and even used a little bit of rtv to try to give it a better seal. still no luck. Does anyone have any suggestions on how to deal with this problem?
Also, what is involved with bypassing the cold start injector? And what are the advantages/disadvantages?
Thanks alot
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLp siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73
Modded 700-R4, 2800 stall converter
NO recent time slips.
Old Jun 23, 2001 | 10:13 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
It is quite possible that at some time either you or someone prior didn't get the cold start injector seated correctly when they tightened it. Thereby bending it if was a bit over the lip.
Trust me, I did this and it's real easy to do. Look at the flange that holds the injector and make sure it's totally flat not curved.
Old Jun 24, 2001 | 10:25 AM
Yeah, I have tried that. The main thing that i am looking to do is blcok off the injector, but i dont know whats involved or if i will mess something up by doing it. thanks for the suggestion.
*1989 RS
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Jun 24, 2001 | 01:32 PM
Guest
Guest
Posts: n/a
You would need to change to an 89 chip to run without the cold start injector, but actually the 89 chip is a good idea anyway its alot better than the earlier ones.
Are you sure its the injector and not the gasket from the runner to the base? Theres also the PCV connection there, check that too.
Old Jun 28, 2001 | 08:46 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
It may also be the actual intake manifold. Check the tightness of the four middle torx bolts. Mine were so loose I could turn them with a 1/4 drive ratchet.
This cleared up a code 44 I'd been searching months for. It may just appear to be your cold start because of the proximity.
Old Jun 28, 2001 | 09:10 PM
thanks for all of the advice guys. the problem is fixed now. i took someone's advice and block off the CSI with 3 nickels and some rtv. the car starts up fine without the CSI connected so im gonna just leave it like this. thanks again for the help
*1989 RS
*355 CID
Old Jul 1, 2001 | 11:35 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Bwaaaaaaaaah...... My car's worth more than yours........LOL
I used about 20 dimes to space my reflector strip after I surgically removed some from another lens and had to grind off the mounting spacers.
So if my car ever trashes I know it's at least worth two bucks.......
Old Jul 1, 2001 | 11:43 AM
Vader's Avatar
Who IS that masked man in the reflection of that tail light lens?
Mike, you need to align the rear deck a bit on the left side. Got a few more dimes?
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 1, 2001 | 12:39 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
OK........ $2.60 ..... the right side was off just as bad........LOL.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
