fuel pressure regulator cover/cap - where to get one?
Old Jul 1, 2001 | 11:53 PM
MrJ's Avatar
MrJ
Mine is warped (don't ask, lol). Where can I get a new one? The local Chevy dealer tried to charge me 163 dollars for a new FPR, how messed up is that? All I need is a cap. I never see any TPI cars in junkyards, so that's out of the question. Autozone sells stock FPRs, but when I had the guy show me one, it's just the internals, with the spring and diaphragm, with no cap. Any help would be really appreciated.....
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
Old Jul 2, 2001 | 12:28 AM
whiteroc's Avatar
Since you are in need of a replacement part why don't you get an adjustable fuel pressure regulator while your at it. Post a Part Wanted ad in TGO Classified section for one. I just bought Crane AFPR off of there a week ago for $40 delivered. It made a huge difference when I adjusted the pressure from 42psi to 50psi.
If you don't want to do that I will sell you the stock cover off of mine.
89 IROC-Z 5.7L 2.77 GEARS
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
Best 1/4 E.T. 14.37 @ 95 MPH
Best 1/8 E.T. 9.22 @ 76 MPH
Best 60ft. 2.07
I put the AFPR on, ported the plenum. This run was made last Friday. (6/29/01)
New Best 1/4 E.T. 14.09 @ 97.2 MPH
New Best 1/8 E.T. 9.09 @ 77.4 MPH
New Best 60ft. 2.03
Old Jul 2, 2001 | 02:16 AM
Guest
Guest
Posts: n/a
When I bought one years ago from work (Standard Ignition part) it came with a new cap as well.
Check around, you should be able to get one somewhere.
Old Jul 2, 2001 | 10:13 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There has to be a TON of the orignal "hats" around, given the number of people that have swapped their stock "hat" for an adjustable one.
Was a quarter too much?
Old Jul 2, 2001 | 11:32 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
A quarter can't be too much glenn, i got a nickel and dime in mine which is just under 2 quarters thick
It was a pita to compress on reinstalation and yields 56psi. As soon as i track down a spare set of injectors to get cleaned i'm pulling it an dropping to a quarter which should be ~50 psi, my goal.
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
