Stock 92 305 TPI 5-Speed B4C Camaro....Times????
Old Jul 3, 2001 | 09:34 AM
CamaroX84's Avatar
Anyone have 1/4 mile times for a stock 92 305 TPI 5-Speed Camaro with the B4C and 1LE options? Just picked one up and want to take it to the strip to see if I can get similar times. Thanks in advance.
Old Jul 3, 2001 | 10:09 AM
whiterocz's Avatar
id say high 14s.
Old Jul 3, 2001 | 11:53 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Look in "Chevrolet Police Cars 1955-1996" by Edwin Sanow. If you own a B4C, you'll want this book.
Sanow has the annual test data of police cars as performed by the Michigan State Police in it for all the recent stuff, incl 1992 B4C Camaro.
Also understand that the tests are done with a driver AND a passenger AND a full tank of gas, so you would need to correct the measurements by reducing the car weight by roughly 300 lbs and then using Cartest or QuarterJr so see what they new ET and trap speed would be.
Also, on the manual trans cars. they don't speed shift -- they use the clutch. HTH. - Ken
Old Jul 3, 2001 | 02:28 PM
RW91B4C's Avatar
I ran 14.90s with only a K&N in my stock 91 B4C
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
jaridjohn
Jul 8, 2024 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
