TBI to TPI.....How to keep VATS?
Old Jul 3, 2001 | 03:27 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I want to switch from TBI to TPI...but I want to keep my VATS working....I will be switching from a Speed Density TPI car...using the computer and harness from the TPI car (which I will get from Ebay).....how do I keep my VATS working?
http://users.ticnet.com/mult68
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cat Coming
More to come.
Old Jul 3, 2001 | 05:25 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Simply use an ECM and PROM that would have been equipped w/ PassKey. For example, when I converted to TPI, I used the 1227730 ECM and a '91 TransAm PROM chip. Just make sure you leave the VATS module hooked up, and you run the DK/BLU wire from the module to the ECM. If you use a factory engine harness you won't have much to worry about.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 3, 2001 | 08:14 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
you got me wondering about my swap!iu'm swapping in a 5.7 TPI from a 89 GTA into a 91 305 TBI firebird.does the 89 GTA's have passkey?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jul 3, 2001 | 08:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It should. 1989 is when I think they started in the F-bodies.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Falcon50
Aug 22, 2020 03:26 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Bigold4x4
Sep 28, 2015 05:21 PM
