A Few IAC Questions
Old Jul 3, 2001 | 07:29 PM
Steve R's Avatar
A Few IAC Questions
What and where is my IAC?
And will cleaning it help my performance/mileage?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Jul 3, 2001 | 09:21 PM
irocbsa's Avatar
Your IAC is on the lower half of the throttle body on the passenger's side. It has a square, four wire connector going to it. The IAC is used by the ECM to regulate the air coming into the engine at idle. Cleaning it always helps but unless you are suffering from poor idle quality than it probably hasn't reached the point where it would be a problem. Mileage, no improvement.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 3, 2001 | 09:57 PM
Vader's Avatar
In other words, right here:
If you do remove it for cleaning, make sure the pintle is fully retracted againast the return spring before you install it and torque the IAC to the proper specs. (13 ft/lb for '85-'89 , 30 in/lb for 1990-on.)
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
