Is this a bad thing??
Old Jul 3, 2001 | 12:03 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
I just finished installing a super ram plenum/runner kit on top of my 355. I also noticed after bolting the plenum on (gasp) that I didn't put the two manifold to runner bolts in that go in from the the manifold side. I have all the runner to manifold bolts that go in from the outside tightened and I'm hoping this will be good enough. Honestly, is it? I don't want coolant to leak from these bolts not being in, I'm not too worried about air leaking though, unless it's major, and I sure as hell don't want to have to re-install the plenum again.
Old Jul 3, 2001 | 12:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
IF you are talking about the 2 bolts that hold the runner on, one in the left rear, the other in the right front. Then were on the same page. IF you are running SD, then I would be only a little concerned. You might have alot of tuning problems if you are running MAF. Leaks & MAF are BAAAAADDD
As far as collent...hmm, if there the bolts I am thinking about then no, you should be fine, there is no collent that goes up the runners.
IF there is something else that I am not thinking about that your describing, then I dunno.
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jul 3, 2001 | 01:48 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Thanks for the reply. Yeah those are the two bolts I'm talking about and I am running MAF. Anybody else have any thoughts?
Old Jul 6, 2001 | 05:51 PM
rezinn's Avatar
Those bolts wont cause any leaks at all, they dont go all the way through the runners, nor do they go into any passages in the manifold. I would put them in anyway, though. They are just to hold the runners down.
Old Jul 6, 2001 | 09:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm not familar with those runners, but if there's a gasket between the surfaces that the missing bolt gos through, then best bet is to install the bolt.
Reason? You may think a little air (actually vacuum) leak is okay, but it's not, ask all the guys with melted pistons, broken skirts, code 44's, etc.
Besides, you're banking on the fact that the vacuum leak would be constant and even to both sides...most likely not.
Now if the bolts are for something else, excuse my ramblings.
Old Jul 6, 2001 | 09:54 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Okfoz, actually SD is not that forgiving with a vacuum leak either as it does affect the MAP reading.
I too vote in installing the bolts as any vacuum leak is going to cause problems.
xxx3man`
Sep 23, 2015 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
Bob88GTA
Aug 18, 2015 03:31 PM
