Miniram on L98
Old Jul 9, 2001 | 02:50 AM
BenDoe's Avatar
Miniram on L98
I think i might have found my next engine combo. I'm thinking of getting an 89 corvette l98 engine with the aluminum heads. My setup would be L98 heads, .488/.495 212/218 Comp Cam, full exhaust, a miniram, and a REAL self made custom chip. I'm only hoping to run low 13's or high 12's and still be a daily driver. Question is, would i need to have my L98 heads ported with 1.6 RR to achieve this goal?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Jul 9, 2001 | 01:31 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I would port them, or if that bill turns out to be mucho $... just use the $ for AFR's and sell the L98's and you'll be lotsa hp ahead for less $.
Old Jul 9, 2001 | 02:29 PM
Guest
Guest
Posts: n/a
I'd port the heads, but you dont need the miniram for low 13's high 12's.
That cam is too small for the miniram anyway.
Old Jul 9, 2001 | 10:04 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
stay away from the miniram on a 350 you really dont need it use a superram or a hiflo system(tpis,as&m,eddelbrock,etc.)
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,1 5/8 headers,y-pipe,edelbrock base,hi flo cat,air foil,afpr,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60'
superram and chip coming soon
Old Jul 9, 2001 | 10:52 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I too would suggest a "1 step larger" cam if you plan to use a Miniram. Whether you use Superram or Miniram, make sure you match the cam to the induction. A great cam for a Superram is not for a Miniram and vice versa.
I notice that a single pattern cam gives fairly good results for a Superram and a dual pattern (like you are suggesting) is better for the Miniram. I would just get one step larger for the Miniram.
BTW, I notice you are looking at an 89 Vette. What type of transmission and are you going to retain the MAF or convert to SD?
Old Jul 9, 2001 | 11:37 PM
BenDoe's Avatar
It would be a 89 l98 vette engine, with my t5 5spd. I would keep my speed density system
gixxer92
Apr 12, 2022 12:09 AM
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
