Wut happends if i start my car while...
Wut happends if i start my car with the two diagnostic terminals jumped? (A&B?)
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
It will fry your computer!!!!!!
I hope you didnt already do it
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
<font face="Verdana, Arial" size="2">Originally posted by Chris Etemadi:
</font>
</font>
Car: '91 Formula
<font face="Verdana, Arial" size="2">It will fry your computer!!!!!!
I hope you didnt already do it</font>
That's great!But really, if you start your car with terminals A&B jumped, it should put the ECM into field service mode where you can see whether you're running in closed or open loop, and once you're in closed loop, whether you're running rich, good, or lean. You can probably tell other stuff too, but I don't know how to read it, so, bah.
SO REALLY WUT WILL HAPPEN? i heard that it can screw ur computer, but i did it to my friends camaro when his EGR was causing his car not to start (stuck open), and i knew that jumping that would bypass all the sensors, and it started right up. so how should i do it? im confused.
Wrong guys. It can damage the ECM to start the car with the diagnostic terminals jumped. For field service mode, you must jump the diagnostic terminals AFTER the car has been started.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
1990 IROC 350
Well...? I started my car 3 months ago with the a-b connected. I have not had any problems (no SES codes) since. So what is suppose to happen now? Fried ECMs tend not to work so good. Don't you think GM would have thought someone would make the mistake of doing this even at the Dealership Service level and made a failsafe integrated into the system? Are we guessing here or does someone have something to back up this Fried ECM Theory?
Okay, so you won't take my word for it but maybe this previous post from Vader will clear things up:
"DON'T attempt to start the engine or even crank it with a jumper in the ALDL diagnostic terminal. You can possibly cause ECM damage. Instead, start the engine, allow it to run for a moment, then install the jumper.
Field Service Mode
On the OBDI ECMs, you can jump 'A' and 'B' terminals on the ALDL while the engine is
running.
WARNING! This must be done after the engine is running. This is called "Field Service
Mode" and will not harm the ECM.
If the ECM is in Open-Loop mode, the SES light will flash rapidly, about 2½ times per
second. If it's in Closed-Loop mode, it will flash about once per second. When in Closed Loop mode, flashing less than once per second indicates the ECM is enriching the mixture above the 128 count base line. Flashing more than once per second indicates the ECM is leaning the mixture below the 128 base line.
A 3.9K resistor installed in ALDL terminals 'A' and 'B' forces the ECM into Backup Fuel
Mode. This mode forces the ECM to use predetermined fuel calculations in the ECM
PROM instead of the learned inputs in active RAM. This is commonly referred to as
the "Limp Home" mode of operation."
Notice it says POSSIBLY cause ECM damage, which means you got lucky
Field Service Mode
running.
. Needless to say I won't be starting it with the jumper in the ALDL terminal anymore. I forgot I had it hooked up when I started it. I knew you could have it running with it hooked up but not at start up. Thanks for the heads up guys. ...glad I got lucky.
well, on my friends car, it wouldn't start unless u jumped A&B terminals. and then once it started, i unpluged my jumper, and the car ran in closed loop (i think). whatever mode is doesn't use any readings from the sensors.
This is a direct quote from the factory service manual. " NOTICE: To prevent ECM damage, the key must be "OFF" when disconnecting or reconnecting power to the ECM (for example battery cable, ECM pigtail, ECM fuse, jumper cables, etc.)."
That is the only reference to ecm damage in the FACTORY service manual(they should know).
I've personally started it numerous times with A and B jumpered without any damage when checking things before I bought diacom.
86 406
I've personally started it numerous times with A and B jumpered without any damage when checking things before I bought diacom.------------------
86 406
I've started up with A&B jumpered lots of times. I'll have to check again, but I'm pretty sure my '85 S-10 factory shop manual tells you to start it with the jumper if you want to enter field service mode! Granted its a different ECM, but I'm sure the same procedures would apply.
Car: Death Mobile
Engine: 666 c.i.
Diacom actually warns you to NOT start Diacom until the engine is running. But I have MANY TIMES started my engine while Diacom is running.
I think a lot has to do with what type of ECM you have. The newer TPI 7730s (and probably 165s) are not as critical.
Yes, jumping will put you in Service Mode which causes the ECM to use different settings than the eprom. This is something I point out to users of Diacom to MAKE SURE they are in Normal Mode as Diacom defaults to ALDL Mode and actually overrides certain settings in the eprom. With the jumper, the ecm is not operating properly.
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Aren't you supposed to have these jumped when you set minimum idle while resetting your IAC motor???
Correct me if I'm wrong but I thought the procedure was
1 - jump A & B terminals
2 - turn ignition on for 30 seconds
3 - disconnect IAC
4 - start engine
5 - set idle to 450 (or whatever)
6 - shut off engine
7 - reconnect IAC
3 - disconnect IAC
4 - start engine
6 - shut off engine
7 - reconnect IAC
