ZZ4 355 Injector size question
Old Jan 27, 2008 | 02:01 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
Hey all -
I'm building a 355 block and was going to throw on zz4 heads and a zz4 cam. I also was going to throw on a complete aftermarket TPI as well - and from what I've heard I should be about ~350 HP. A while back I bought 30# Ford SVO injectors, but now I'm thinking they're too big and I should just throw in some 24#ers. Any advice?
Old Jan 27, 2008 | 02:12 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: ZZ4 355 Injector size question
The 24 #/hr Ford injectors are the best for you along with an AFPR. You could maybe get away with the 30s, but an EProm chip modification is required.
I am at the limit of my 24s on my 395 cu.in. stroker. I intend to buy 30 #/hr injectors this Spring.
Old Jan 28, 2008 | 10:27 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
24lbs are what u need. with a adjustable regulator. the 24lb should support 400-450hp.... 30lb are good for 500-550ho. NA of course. go with ford SVO... they are better and the 30lb ford SVO is the same as 32lb accels etc. they flow more than the lb rating.
im got 30lb SVOs for my HSR 383. with about 460-500hp.
Old Jan 28, 2008 | 11:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yep 24's will be perfect match. 30's are for hotter 350's and mild to medium build 383's. hot 383's will want 36's+
Old Jan 28, 2008 | 11:43 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
I have 36lb injectors on my vette, and it runs just right, of course it has been tuned well also.
Old Jan 28, 2008 | 11:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I personally have had good luck with the GM LT1 injectors, they are 24# @ 43.5 psi. I run a set in a TPI 305 that has the factory GM regulator @ 46 psi. Couldn't ask for better performance or fuel economy.
Old Jan 29, 2008 | 12:08 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Fast355: what you posted is NOT entirely correct. LS1 cars came with two types of injectors, my '99 factory injectors would flow 24 #/hr at 43psi (as you stated), however, 2001 and 2002 ls1 cars came with the equivalent of 26 #/hr injectors. At the fuel pressure (58 psi) in the LS1 F-bodies, these injectors are rated at 26.5 and 28.5 #/hr, respectively.
BTW: the Ford Racing (formerly SVO) fuel injectors are the highest quality injectors that you can buy.
Old Jan 29, 2008 | 12:40 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
He said LT1 not LS1 i thought?...
Old Jan 29, 2008 | 03:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
GM LT1 injectors
yep, he said LT1 and they had 24 lbs injectors
Old Jan 29, 2008 | 06:39 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
yep, I stand corrected!!!!!
Old Jan 30, 2008 | 11:04 AM
Abubaca's Avatar
Not to hijack, but with an AFPR and LT1 24#, do I need a new tune? Opinions seem to vary with only a 2# difference from stock.
Old Jan 30, 2008 | 01:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you can get away with it, but depends on the other mods. 2lbs of difference will definately make the car run rich and most factory tunes are rich with stock injectors. I know my car was.
If you have supporting mods like great exhaust, and alot of TPI bolt ons or other intake, then it will work better but still will be richer than it should be.
Old Jan 30, 2008 | 07:11 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Our ECMs make fuel adjustments as high as 23% more fuel, to 16% less fuel, while the ECM is in closed loop. A 2# difference in fuel injector flow rate is about 9% change. So for cruising around the ECM should be happy. The question is what is the AFR at WOT. That is where we need an AFPR and do some testing, or better yet, use a wide band O2 sensor.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
