Car bogs around 3700 RPM
Old Jan 28, 2008 | 10:49 PM
thomeygun1's Avatar
Car: 91 TA
i have a 91 TA and when i floor my car it starts to bog around 3900 RPM. if i dont floor it all the way it will go up to 5000 RPM though..also my check engine light comes on and off occasionally since i have noticed this..any help is appreciated thanks
Old Jan 29, 2008 | 10:40 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: Car bogs around 3700 RPM
o2 sensor or mabe a plugged cat??
Old Jan 29, 2008 | 06:17 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
check u TPS sensor... they can go bad after a certain amount of throttle... the numbers will become irratic when the peddel is heald steady...
another thing can be the ignition modual in the distributer... bad moduals have a tendency to bog the car down and create a miss in the upper RPMs.
get that code read and start from there. check all your sensors.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
specialized
Jun 18, 2022 09:26 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
hokis
Aug 9, 2015 03:57 PM
killer777
Aug 8, 2015 02:47 PM
