Plenum and Runner Interchangability Between Years.
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Are plenums and runners interchangable from an '86 TPI 305 and a '91 L98. I just put a '91 L98 in my car and while Im driving my car, I can polish and port my plenum and runners from the 86 intake then just switch the two.
Maybe then I'd polish the '91 and sell it.
Fire fighting, Scuba Diving, and Fast cars.....Does life get any more exciting
'86 TPi T/A L98
Stuff on Order:
Ram Air Hood
4th gen Spoiler
Borla exhaust
Sub Frame Connectors
STB
and a bunch of other stuff
Q?-Does Prowler orange sound like it will look good on my T/A?
AOL Screen Name, Madbiker1
'86 TPi T/A L98
Stuff on Order:
Ram Air Hood
4th gen Spoiler
Borla exhaust
STB
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
84-88-these have a cold start injector that is attached to the driver side runner and has a fuel line that runs from the cold start injector(9th injector)to the back of the driver side fuel rail.these two holes can be plugged for use in later model cars
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Car: 1985 Trans Am
Bandit: I you mean 85-88, there was no TPI in 84.
You will also need to drill a port on the back of the passenger side of the plenum for the MAP sensor that the 90-92 TPI uses.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Kevin Irving
Royal_Z
Sep 30, 2015 08:45 PM
