w00t!! First 1/4 mile
Old Jul 14, 2001 | 12:31 AM
IROC-Z_85's Avatar
I just thought i'd use my favorite board (tpi) to share that i ran my first quarter mile at a strip tonight. Got a total of 3 runs best being 15.079@92.40 with a .882 reaction time (pretty bad) and i KNOW the car has alot more to give, i feel i could squeeze a 14.5 or maybe even less when i get comfortable.....
What i dont understand is i could NOT hook up.. I mean well after leaving the line i was still spinning..
So anywho, the question part about this is WHATS NEXT. After SD and headers what do i do with my tpi to get me to the 13s
(also how do i get my car into over drive when i have the pedal pinned? i need another gear desperatly)
1985 IROC-Z, nuff said :P
[This message has been edited by IROC-Z_85 (edited July 13, 2001).]
Old Jul 14, 2001 | 12:58 PM
mirage2991's Avatar
please let every one know what you have for motor....so we can direct you onto the right path...
Old Jul 14, 2001 | 01:02 PM
mirage2991's Avatar
oh yea...slicks baby, slicks...I can't hook up at all either, and if I had the $$ I'd get slicks...(but I rather spend the $$ on slicks for the 69...hehe)...if you car can't hook, then it's wasting hp...I could only hook once, when they had the pro-stock running, and I pulled a 2.0 60' on radials...every other times, it's like 2.2 to 2.4...
also, gears, no more than 3.42, I recommend 3.23's...trus me on this, I have experimented, and 3.23's really works out well...and I still go sideways with part throtle .....
Old Jul 14, 2001 | 01:31 PM
IROC5.7TPI's Avatar
Have to master the launch.
See the topic in the theoretical and street racing forum.
What were your 60 ft. times? Improve them and improve ET
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jul 14, 2001 | 03:35 PM
IROC-Z_85's Avatar
best 60' 2.227
Car is 305 TPI, airfoil/K&N/ported plenum/gutted air box. Adj FPR, shift kit, 3.73 + auburn pro series posi (thats why i need another gear) Dual exhaust with H-pipe from the manifolds back, no cats.
And a compucam 2030
Old Jul 14, 2001 | 05:16 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you don't need another gear(shifting into o/d @the end of the run will cost you big time.all you need to do is get that engine to pull a little higher in the rpm band (runners baseplate plenum etc.)that will give you the 500 extra rpm's between gears or you could go with taller overall tire height which effectivly reduces your gear ratio instead of 16/50/245's go with 16/60or65/245 it will raise the overall tire height for you
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
ed wright's fastchip saturday!!!!slp catback is finally on!!!
FLOWMASTER S.U.C.K.S
Old Jul 14, 2001 | 07:33 PM
IROC-Z_85's Avatar
Yea im changing tire size anyways, so I think i'll run 60's.
But remember im running 3.73's and a 107k mile engine, revving high doesn't work to well
Old Jul 14, 2001 | 09:26 PM
FlashGTA
Guest
Posts: n/a
To get your car to hook you need to change the pinion angle and the instant center. Using Spohn LCA relocation brackets will help move the instant center back better loading the tires. The stock pinion angle is an incredibly bad 1/2 degree negative. You want 2 to 4 degrees of negative pinion angle to get the tires planted (adjustable torque arm) You also need to maintain that pinion angle and not allow the rear to rotate to ruin your pinion angle, this means good LCA's with Poly bushings and a poly torque arm bushing. Last but not least you need weight transfer. Disconnect the front sway bar is the only easy way to help that.
Old Jul 14, 2001 | 09:30 PM
IROC-Z_85's Avatar
Daily driver man
aint disconnecting NUFFIN :P
Old Jul 14, 2001 | 09:52 PM
leirch's Avatar
I'm not one to speak of the 3.73's but when the time comes and the gears "break"(when i have a better tranny that allows for the rear end to break), i'm definatly going to 3.23/3.27's.
And as far as the daily driver goes. I hear you on that one. I'm out of first gear in the first 80feet usually, if that. I can't even imagine running 3.73's without something that lets you go to 6k rpms easily..I shift at 6k because the shortblock is running at best 120psi for compression.. go figure...
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 14, 2001 | 11:06 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
the 3.73's are killing you, I had the same in my monte and every time I punched it, there went the tires. I broke those stuck with 2.73s and I cant break, but they are too high to get a good launch but are great with the overdrive on the highway, 100 mph at about 2800 (dont shoot me on that trying to remember for sure, but I think its close). Im looking for 3.42 for good take offs.
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. So if anyone knows where a buick GN 8.5" rear is let me know.
Old Jul 14, 2001 | 11:11 PM
IROC-Z_85's Avatar
Well the car came with 3.42's
I went to 3.73's knowing there was a bigger engine coming, but even with a bigger tpi engine i still aren't gunna be able to rev for ****
Spose i need to go back to 3.42
bad move on my part, i suck
Old Jul 15, 2001 | 07:37 AM
86ZZ4's Avatar
3:73 are tough on a TPI motor,even with simese runners ans ported intake and plenum,im going through at over 5000.Ran my best MPH when i accidenly bumped it into 4th
LOL,gained about 1.5 MPH by that.Gonna try some taller tires first,see how they do.
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
Old Jul 15, 2001 | 01:46 PM
IROC-Z_85's Avatar
Anybody wanna buy some 1month old richmond ring and pinion 3.73's?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
