LOTS OF CRANKS TO START/NO SES LIGHT WITH KEY ON
Car: 87' T/A, 83' caprice classic & Zx7R
Engine: TPI 5.7 , 71'350 4blt main
Transmission: 700r4 , 700r4,6speed Stacked
Axle/Gears: 3:42LSD , 2:55open 15f,43r chain
HERE IS MY PROB YEARS AGO I TRIED TO BYPASS MY MAF ON THE 87'T/A AND BLEW OUT MY ECU I HAD A NEW ONE INSTALED CAR RUNS BUT SINCE IT HAS TO TURN OVER FOR A WHILE TO RUN SO I FGURED THE ECU WAS BAD I BOUGHT A NEW ONE AND PUT IT IN MYSELF SAME PROB I ALSO FOUND OUT I HAVE HYPERTEC CHIP IN THE ECU. THE SWAP WAS SIMPLE NOW SOMETIMES THE CAR WILL START RIGHT AWAY BUT USUALY TAKES ACOUPLE 1000 OR SO CRANKS(REALY 5 TO 20 SEC ) AND RIGHT BEFOR IT CATCHES MY SES LIGHT COMES ON BUT IF I TURN THE KEY TO THE ON POS WITH THE CAR OFF I GET NO SES LIGHT BEFORE THIS HAPPENED I REMEMBER THE LIGHT USED TO COME ON WITH THE CAR OFF KEY ON. WHAT COULD BE MY PROB I HAVE CHECKED MY PUMP @ THE TANK AND @ THE SHADER VALVE HAD LOTS OF FUN UNDER THE TAP RINSING GAS OUT OF MY EYE'S SO I HAVE PLENTY OF F.P. ALSO I HAVE TO HOLD THE GAS PEADL DWN SLIGHTY TO START WHEN THE LIGHT COMES ON AS WELL NO MATTER WHERE I SET THE IDLE AND IT INST DROPPING ANY CODES
PLEASE HELP
SORRY FOR THE CAPS LOCK POST WAS TO LONG ONCE I REALIZED IT WAS ON
PLEASE HELP SORRY FOR THE CAPS LOCK POST WAS TO LONG ONCE I REALIZED IT WAS ON
Re: LOTS OF CRANKS TO START/NO SES LIGHT WITH KEY ON
Holy crap.
it may not be the ECU thats causing your problem. Timing being off, low fuel pressure, pressure regulator, bad sensor like TPS or CTS, or even something out there like poor wiring to the ECM. Or a combination of them all could be the culprit.
Or it could be the ECM, hard to say.
Car: 1985 Chevrolet Camaro IROC-Z28
I have a problem with my fuel pump relay system, and have to crank it long enough to get oil pressure before mine will fire up. Once that oil pressure builds my pump comes on, and it starts instantly. Does your pump prime when you set key to run? (I know you have pressure, but I'm wondering if your pump actually runs)
when i turn it to the on position i can hear it turn on but i am not sure if it comes back on once i start cranking
If the fuel pump runs a two-second prime cycle on ignition power-up, the ECM is at least functioning. Why the SES is not turning on is not known, but could be a connection anywhere between the ECM and the instrument panel. Such a connection could also be the reason the engine doesn't start immediately. Get the SES working, and you may find the root problem for the no-start.
eightsixseven
Dec 16, 2024 01:50 PM
ambainb
Apr 25, 2016 09:21 PM
