TPI vs LTx throttle body questions
Old Feb 5, 2008 | 07:18 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Looking at the LT1 throttle bodys vs the TPI ones. Can the IAC plate off of one, cross over to the other?
I do see the TPS is different.
What about throttle cables?
mounting bolt pattern?
Lastly, if I have a 350, 810 swirl port heads, stock intake, headers, unknown truck cam. Think I will see a gain by going up to just 52mm?
Old Feb 5, 2008 | 07:49 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: TPI vs LTx throttle body questions
I think the two will interchange with some minor wire mods.
The stock size tb will do fine.
Old Feb 5, 2008 | 08:05 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks.
Wire modification is noooooooooo problem
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
