done with siamesing :)
Old Jul 19, 2001 | 06:03 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
its great. finally got all the kinks worked out and took it for a test drive
i can't notice much of a loss in low end torque if there is any. but i notice a huge difference from 3000 to 4500 rpms and from 4500 to 5500 it doesn't fall off much if any. 5500 is my redline and i didn't go past there cuz of the stock valvetrain.
this is on a 305 with the stuff listed in my sig plus i installed a blaster coil to help with my top end spark. new wires are in the box to be installed that will help also.
remember this is all on the stock chip. when i get to burning my own chip i'll be in the 13's for sure.
i can't wait
if you have the ability to siamese your intake i say do it.
i only went 1.5 inches into the intake. i will go more when i get new heads and cam. say to 3-4 inches
i'll post pics when i get the developed
Andrew
Andrew Peery
1987 IROC, 305 TPI, T5
Hooker Competition Ceramic Coated Headers, Flowmaster, Ported Plenum
All smog equipment gone and no cat
before headers
192hp and 265tq
15.20 @ 92.5 mph 2.4 60ft
After Headers
14.480 @ 95.01mph 2.194 60ft
Old Jul 19, 2001 | 06:23 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
so what would you say your total runner length is now??
oh and post some pics or times because this is one of my favorite topics as of late.
james
Old Jul 19, 2001 | 06:35 PM
IROC-Z_85's Avatar
What runners are you using? stock?
Do you have siamesed runners?
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
Old Jul 19, 2001 | 10:50 PM
Car: 87 IROC
Transmission: 5spd
i have the stock runners. i really do not know what my runner length would be. i'm kinda confused on that because what i intended was to make the runners act as part of the plenum. thus siamesing the intake makes each intake port be able to draw from each runner making the runners act like the plenum at a higher rpm but at a lower rpm the runner would still help in acting like a longtube design (since i didn't cut too deep) and i think that is why i didn't loose any low end torque (that i can tell i may have lost like 5-10 but you can't notice that)
my whole goal was to make my car run better from 3k on up and i accomplished that. there is a much broader powerband and less fall off after 4500 rpm and i can pull to 5500 rpm with ease.
i run through 1st and 2nd gear like they aren't there and 3rd gear is in the powerband perfectly. i didn't run it up to 4th but i will later. it should pull much better now.
Andrew
Old Jul 20, 2001 | 06:10 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Here is some pics of what it pobably looks like. I think some siameesed runners will really help. TPI Base
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 20, 2001 | 07:43 PM
Car: 87 IROC
Transmission: 5spd
yes that is what it looks like except i knife edged mine a lot more. tried to make a nice transition to where the siamesing stopped.
Andrew
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
JHX
Sep 3, 2015 07:55 AM
Night Hawk
Aftermarket Product Review
Apr 13, 2001 02:12 AM
My90Iroc
Apr 12, 2001 09:52 PM
Ward
Dec 3, 2000 06:51 PM
