so confused.
Old Feb 6, 2008 | 11:46 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
so confused.
Okay guys im going to buy myself an hsr setup. Thing is im putting it on my stock motor now. But i will be buying vortec heads soon. Any problems? How will the bolt patterns work there? Any machining?
Old Feb 7, 2008 | 09:32 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: so confused.
The vortec heads have a different intake manifold mounting. I do not recall if it was port location, or something else, however, I do know that a standard manifold will NOT fit vortec heads. I do not beleive any amount of machining will alter that fact.....
Old Feb 14, 2008 | 11:55 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: so confused.
the only difference is the bolt pattern. If the HSR has the "old" style pattern you will need to enlogate the center bolt holes on the manifold.
Old Feb 14, 2008 | 01:44 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: so confused.
Sorry Bob, but that is not correct. The Vortech heads also have much taller intake ports, which are taller than the entire stock intake manifold, so would require extensive welding and machining on the HSR to make it work. Go with the AFR's that are designed for the older style intakes, you'll save yourself a lot of headaches, have better heads, and still be able to use your HSR.
TA
Old Feb 14, 2008 | 03:17 PM
Pocket's Avatar
Car: 91 Trans Am
Re: so confused.
Or you could buy the vortec specific HSR
Since he seems to be buying new this wont be much of an issue
Old Feb 18, 2008 | 10:35 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Re: so confused.
he ended up buying a regular style one... ill pass on the vortec info... you are correct i was thinking of the change from Pre 86 to 86+ for some reason....
Old Feb 18, 2008 | 11:40 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: so confused.
Ya ima just buy a side engine and buil it up. Then toss my hsr on it and call it a day
Galaxie500XL
Feb 1, 2020 04:53 AM
ski_dwn_it
May 29, 2002 06:55 AM
ryn28
May 27, 2002 11:09 AM
uk89camaro
May 19, 2002 01:35 AM
Supercharged84Z
Theoretical and Street Racing
Dec 22, 2001 11:16 PM
