Bad MAF sensor?
Old Jul 22, 2001 | 09:59 AM
areynolds23's Avatar
Bad MAF sensor?
I have a '87 IROC with a 305 TPI. When I plug up the MAF sensor the car runs really bad but it runs perfectly when unpluged. Do I replace the MAF sensor ($300) or do I just leave it unpluged.
Old Jul 22, 2001 | 10:05 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i'm assuming that your ses light stays lit no matter how it's hooked up.whenthe maf goes bad you go into limp home mode when this occursit might feel better but thecomputer is limited by the base perrametters and locks the timing whichh means no advance.if you are justt driving and are not looking for performance leave it off,if you want the car tto run rightt i would replace it
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'(auto ET)
slp catback is finally on!!!
fastchip prom is in.
kicks you in the *** at wot.
FLOWMASTER S.U.C.K.S
Old Jul 22, 2001 | 02:24 PM
No the ses light isn't on
Old Jul 22, 2001 | 08:16 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Your SES lightbulb may be burned out. I would check your codes with an Auto X-Ray if you have one or can borrow one.
You can get a remanufactured Bosch MAF from Autozone or Kragen with a 1 year warranty for 139.00 exchange under the name A1-Cardone.
Old Jul 23, 2001 | 07:32 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
300$$ get a wells su-145 MAF for 170$$ flows beter than Bosch. Do a search and you will find a link were you can buy it. ( have the adress at work...)
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a Canfield headed 383 in the works!! ready May 2001...ok..june...july..and with Accel DFI....looking for SR or miniram....
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
89GTAOz
May 16, 2020 09:31 AM
chazman
Aug 28, 2018 03:25 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
