help asap car turns but wont start
Old Jul 19, 2001 | 01:00 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i just got my intake and everything back on. no i turn the key and the car turns over but won't start. if you pump the gas it kinda pops a little but it seems like the timing is off or the plugs out of order. i checked the timing with the electronic spark advance off and the timing is at top dead center but it still will not start.
any help is greatly appreciated.
i did have the distributor out if that makes a difference but i did install it where it was. plus the timing is on so why would it not start.
i have checked all the connections and they are all secure.
man i hate it when this stuff happens.
Old Jul 19, 2001 | 02:54 PM
IROC-Z_85's Avatar
Take out the number 1 plug
(front right)
put your finger over the hole, and turn the crank till the timing mark is lined up with TDC and you feel the compression PUSHING on your finger, then you KNOW its TDC. Sounds like your distributor isn't in right at all...
Also make sure all you have all electronics plugged into the distributor
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
Old Jul 19, 2001 | 03:19 PM
Car: 87 IROC
Transmission: 5spd
ok everyting is plugged in. i did the turn it and it was at tdc as far as i know. so what else could it be? it has to be something with the spark.
thanks
Andrew
Old Jul 22, 2001 | 08:15 PM
Ben87GTA's Avatar
Im having the exact same problem.. does anyone have any idea on how to cure this? I've tried adjusting the lash from everywhere from 0-1.5 turns.. no go. the distributor is in correctly.. same with the plug ordering.. I've checked over and over again the connectors... also, when I turn it over, now it pops from both the INTAKE AND the EXHAUST... no idea.. help!!!!!!!!
Old Jul 22, 2001 | 08:20 PM
Car: 87 IROC
Transmission: 5spd
i sent ya an email but i don't think what i said is gonna help you if everything is correct.
if its popping both ways then it must be off 180 degrees cuz being off half a turn it would be igniting when the intake and exhaust valves would be opening and closing
just my thoughts
Andrew
Old Jul 23, 2001 | 12:25 AM
Ben87GTA's Avatar
got it all fixed.. the dist was in 180deg off... so i just rotated the cap 180, and reversed the plug order. i hate taking that damn bolt out that holds it in. my luck I'd drop it in there and have to pull the engine..thanks for the help everyone.. thirdgen.org comes through once again
Old Jul 23, 2001 | 01:08 AM
87tpi420's Avatar
smokin87 needs to make sure he didnt do the same thing, if you line up the timing mark on the balancer, you are either on with the timing....or 180 off.
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Jul 23, 2001 | 12:01 PM
Car: 87 IROC
Transmission: 5spd
yes i had done the same thing but i got it fixed that day. its frustrating when your timing lines up when you crank it over but it doesn't start
Andrew
Steven 86IROC-Z
May 24, 2026 04:52 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
