Holy Sh***, FIRE!!!!!!
Old Jul 23, 2001 | 05:26 PM
Crushin91's Avatar
I finally got my motor back together this weekend. For the first time in over a year, I cranked it over and BAM, the thing roared! I was f'n pumped!!
So today I went out to tighten up any vaccum leaks, set the AFPR, and set the timing. As I brought the motor up to around 2500rpms, the number 6 injector started spraying raw gas all over the place! I pulled the coil wire off with my bare hands to kill the motor, but the gas had already caught. It took me only about 10 seconds to grab my CO2 extinguisher and put the fire out! I looked for damage, which thankfully was pretty minimal. Most of the flame was just the raw gas burning off, but some of the hard plactis vaccum lines seemed to be a little warped. The injectors lines were cool, as well as the MAP sensor, ect. I guess I got away pretty clean for the amount of flames. Anyways, I started to look for the cause of the gas leak and found that one of the injector clips got bent while I was reinstalling the fuel rail. That bend was just enought to unseat the o-ring and cause the leak. Now, after spending the last 3 months trial fitting all the aftermarket injection pieces, everything has to come back off to fit the clip, what a BITCH!
Anyways, I just thought about the $20 that little Pepboys extinguisher cost and how much money it just saved me. I found out the hard way how tricky Fuel injection can be! So if anybody says, "don't worry about the clips, you will be fine", stop and take the time to check those things, cause I just found out how ugly a broken $2 piece can make your how day!!
Crushin
p.s. Sorry to vent, but I thought an FYI might help somebody out before it happens to them!
Hugger Orange '91 L98 Z
Old Jul 23, 2001 | 05:32 PM
1990 IROCZ's Avatar
Damn dude!!
That's hella crazy, good thing that extinguisher wasn't too far away, that would scare the hell out of me!!
[This message has been edited by 1990 IROCZ (edited July 23, 2001).]
Old Jul 23, 2001 | 07:28 PM
IROC-Z_85's Avatar
Well congrats on the successfull project!!!
A fire on first crank is always great
and sorry about the scare
but looks like all in all it came out well
Smart having ane extinguiser around!
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
Old Jul 23, 2001 | 07:54 PM
b92z28's Avatar
i know how you feel about things going wrong on the first crank. the first time i fired the 377 in my bird i somehow forgot to hook the brake booster line into the back of my carb.... 11:30 at night i fired her off was sounding great. then from the drivers seat i saw a nice glow from the engine compartment. ever seen slp 1 3/4s get red hot? boy was i glad i used forged pistons!
Old Jul 23, 2001 | 08:50 PM
Crushin91's Avatar
Yeah, I found out about those vacumm leaks early on too! Before all the fire ****, I had a loose runner bolt. When the car first fired, it shot up to like 4000rpm right away! Scared the **** out of me, but not as bad as the damn fire.
Old Jul 23, 2001 | 10:18 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
SUCK'S don't it. YES you did get by lucky. My car didn't fare so well. POOR THING from the looks of it it must have been burning for 1/2 an hour or so. I think it too was a fuel leak because everything on the pass. side top of the motor was gone. It took all plastic and rubber pieces it could find. It even took the hood. But I bought it that way in hopes to get it running soon. I am 3/4 way done with it and it should be only a few weeks left till.....
I turn the key and it fires up. By the way I will be armed with a fire extinguisher. It is a 1987 Trans Am GTA 350 TPI digital dash, Black with the Gold wheels. F'n sweet looking. CAN"T WAIT. Once running I will rip my IROC apart to install the new 350.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
had engine fire hope to get running soon
Flowmaster exhaust
Old Jul 24, 2001 | 02:17 PM
leirch's Avatar
I just swapped my old 24lb injectors for some 30lb SVO injectors and hell, it only took about 15hours...!!
I did the same thing on the injector clips, I thought, oh hell, I don't need them. I have a superram unfortunatly and it takes about 2 days just to work on it. I got it apart in 1.5hours, then I went to reassemble it and got the fuel injectors in w/o the clips, then got the runners back on. Glad I pressure checked the system before I Put the plenum back on, the number 6 injector started spraying everywhere!..
On this note,
ALWAYS pressure test the fuel rail after assembly!
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
