Removed cat = lack in power?
Old Jul 25, 2001 | 11:03 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I removed the cat the other day, the car doesn't seem to pull nearly as hard as it used.. is the back pressure too low? whats the deal?
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    !cat
    15.559 @ 88 MPH
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
    Its for sale!!
    Buy me!
Old Jul 25, 2001 | 11:57 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Most people claim a reduction in low-end torque. I personally gained from gutting my cat. Because mine was probably clogged. Tell me, did you just take the stuffing out of it or did you actually stick a pipe in it? Some people claim to lose power when there's no pipe inside the cat. Might want to read the exhaust board. Lots of questions and answers about this over there.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Jul 25, 2001 | 12:40 PM
Omega's Avatar
Engine: LS1 / LS3
I have heard all sorts of stories also. I wasn't sure if TPI engines needed more back pressure than i have... I have no guts and no pipe. I do have a cat i can put on so i will eventually be able to run a pipe through the gutted cat and still have one spare to pass the smog tests.
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
