AFR heads vs Fastburn Heads
Old Jul 25, 2001 | 10:15 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Will be using a ZZ4 short block...and a LT4 hot cam...my goal is 12s in the quarter mile N/A....and a 100hp shot of NOS to get me in the 11s....question is...should I wait for the vortec TPI base....or go ahead and get the AFR heads? Im interested in fuel economy as well as power. And i'll be getting the aluminum verisons. Another thing....im a bit confused as to what I need to buy...I think I will need 1.6 Roller Rockers....and lifters?? But theres a thing on AFR's site that is called Hydra-Rev Hydralic Roller Cam Rev Kit...what is that? And do i need it...basically....what besides the heads and cam do I need to buy to have a complete working engine (keeping in mind I would already have the small block, exhaust system, and intake system.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
Old Jul 26, 2001 | 01:31 AM
Dan87IROC-Z's Avatar
I would suggest the AFRs, they outflow all of the other companies, including the GMPP ones. They are expensive though, close to $1500 for the 190s and 195s.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 26, 2001 | 12:03 PM
FormulaJoe's Avatar
The AFRs are far better heads. The AFR 190s will flow more than the fastburns and have a smaller intake runner (ie, more velocity/ more torque). You will have more potential wiht the AFRs. The fast burn/LT4 hot cam combo works really well though. Thats what Im running on my project car with a ram jet efi setup. Hopefully it will make its claimed 430HP figure.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Jul 26, 2001 | 01:17 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
The Hydra-Rev kit is to keep the valves from floating at higher rpm's. Even roller cams have this problem.
That is why they show an increase of horse power from 6000 rpm and up. If you do not run your motor up that much, you do not need the hyrda-rev kit. (unless of course you just want a sfae-guard for it in case you evr do)
Old Jul 26, 2001 | 05:30 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
for a proven combo the lt4 hot cam and fast burn's are said to be great but you need a good flowing intake to get the combo to rev where it makes the power(miniram or fully ported superram)i would go with the afr's they come cnc machined for consistent flow from runner to runner where the gm's are cast formed leaving larger tolerances a cheaper alternative and i know a guy who has them and loves em is the tf23* head they are cheaper and dont flow to much less without having cnc'd ports or chambers as for a cam that depends on where you want it to live for most street engines(occaisonal track)the superram will be enough
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'(auto ET)
slp catback is finally on!!!
fastchip prom is in.
kicks you in the A.S.S at wot.
FLOWMASTER S.U.C.K.S
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
