Need Help, Should I remove my converter or not??
Old Jul 26, 2001 | 10:54 PM
Jas89TTA's Avatar
I got a 87 Trans Am 350 TPI and my cat is ratteling bad and I either need to replace it with a high flow one or just remove it and put a pipe in it's place. I'm in Florida so there's no emmision checks here, but I've heard that if I remove the cat I'll lose power with the TPI, Is this true? Does it need the back pressure? What was anyones experince by removing the cat on a TPI engine? What was it with a high flow cat?I've already removed all the emissions crap off my car. Any suggestions would help. Thanks, Jason
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, LS1 Aluminum Driveshaft, Flowmaster Exhaust, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
Old Jul 27, 2001 | 01:52 AM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i have a pipe in place of my cat and i noticed a gain. it will allow your car to breath better up top. you may loose a little low end torque but it won't be too noticable since it is a tpi and already has good low end power.
i say take it out. you can always put a new one in if you don't like it but save your money for now
Andrew
Old Jul 27, 2001 | 01:57 AM
Beefy89's Avatar
I removed mine and didn't lose any torque.
Shoot Shoot!!!!!
Old Jul 27, 2001 | 06:08 AM
ImportsRsloths's Avatar
Id remove, dont forget to weld in an oxygen sensor!
Old Jul 27, 2001 | 06:41 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
A good high-flow cat is under $100 these days. Be conscientious of the air that we all breathe and install a new high-flow cat. Unless you are highly modified, you won't see any loss over no cat, and certainly won't vs. a stock cat.
--andrew
1992 Trans Am
May 10, 2023 07:19 PM
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
