TPIS AFPR Problem!!
Old Jul 30, 2001 | 02:22 AM
Crushin91's Avatar
TPIS AFPR Problem!!
The damn vaccum line post stripped out on me! Anyone ever have to fix one??
Hugger Orange '91 L98 Z
[This message has been edited by Crushin91 (edited July 30, 2001).]
Old Jul 30, 2001 | 04:07 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Seems like a very common problem with their POS.
I think someone fixed theirs by epoxying a rivet head in there from the inside. I'd try to return it, but TPIS could be slow on something that isn't putting $$$ in their pockets.
Old Jul 30, 2001 | 08:56 AM
leirch's Avatar
Crushin,
I had the EXACT same problem last week after my 30lb injector swap.. I took some kick *** eproxy and then sanded the AFPR surface down to bare metal, then put the vacumm fitting back in and epoxied it in. After 20minutes your good to go. NO problems now..
Definatly not sucking anymore
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 30, 2001 | 02:27 PM
IROC5.7TPI's Avatar
Sux when you pay good money to a reputable company for a well known mod and it turns out being substandard
SCREW TPIS. I won't buy squat from them again. I had the same problem with my AFPR on my Vette.
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
